Equipment & Tools From test equipment to hand tools
Calibrating electronic Ph meter
Old 13th April 2007, 04:14 PM   #1
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Default Calibrating electronic Ph meter
Is there a way to calibrate an electronic Ph meter?
A liquid with a known stable Ph value would do the trick, only what should I look for?
/Hugo
Old 13th April 2007, 04:38 PM   #2
On Hiatus
SY's Avatar
You want two buffer solutions at pH values which are 3 or 4 apart (for example, pH = 5 and pH = 8). Any chemical supply place will have them.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th April 2007, 04:51 PM   #3
Netlist's Avatar
Thanks, I know a few in town.
As for the trimming, there's only one pot so both liquids will only be able to make me adjust indicatively.
/Hugo
Old 13th April 2007, 08:12 PM   #4
RDL2004 is offline RDL2004  United States
You need what is called "buffer solutions". They are made specifically for calibrating pH meters.
They come in many pH values. For better meters with 2 point calibration you usually use something like 4 and 10.
For meters with only 1 point calibration (which it seems yours is) it is usually best to pick a buffer value near the pH which you will be measuring.
Also, temperature will affect the pH reading, more expensive meters will have built in temperature compensation.
I think the buffers must be at a certain temperature to be the specified pH, probably 25C.
Old 13th April 2007, 08:21 PM   #5
Juergen Knoop is offline Juergen Knoop  Germany
Juergen Knoop's Avatar
afaik, one point trimming is better done with a pH 7 buffer
because the probe change their asymmetry far more, than their slope
I have had several used probes, even really cheap ones, with nearly perfect 57-59mV/pH at room temperature, but asymmetry up to hundreds of mV in one case
I think you can also use pH 4 or 6,81 buffers, this shouldn't matter with a simple pH-stick
just don't use dest. water as some people recommend
it has not pH 7 and the probe will give no reliable readings with such unbuffered water
regards
Old 13th April 2007, 08:50 PM   #6
On Hiatus
SY's Avatar
That's exactly it- "buffer" is the key word. Because pH is logarithmic, a deviation of 1 pH unit on either side of neutral (ph= 7) is a very, very tiny change in hydronium/hydroxyl ion concentration. Purified water will NOT work. As with amplifiers driving a load, a buffer is called for.
Old 13th April 2007, 11:27 PM   #7
XEAGLEKEEPER is offline XEAGLEKEEPER  United States
XEAGLEKEEPER's Avatar
A company called Hach sells the buffer solutions
http://www.hach.com/
Dave
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 14th April 2007, 06:46 AM   #8
Netlist's Avatar
Thanks a lot everyone.
That's a wealth of useful information.
/Hugo
Calibrating electronic Ph meterHide this!Advertise here!
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
Calibrating new tip on Hakko 929-2 / 903 ultrachrome Parts 1 4th January 2006 02:28 AM
I need a portable diy electronic AC volt meter, to avoid transportation of Scopes. destroyer X Solid State 10 21st August 2005 05:38 PM
self-calibrating OPAMP jackinnj Swap Meet 0 27th February 2004 05:03 PM
Calibrating a mic Raka Analogue Source 1 29th January 2003 06:28 PM
Copyright ©1999-2017 diyAudio
