V3 Universal Power Supply Circuit Board - Page 11 - diyAudio
Go Back   Home > Forums > Commercial Sector > The diyAudio Store
The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Old 22nd September 2013, 11:03 AM   #101
acumos is offline acumos  Italy
I'm worried about the thermistor epcos because it's not marked cl-60 but it's 10ohm and 5a
Old 22nd September 2013, 11:05 AM   #102
JojoD818's Avatar
You should first try to source the CL-60, it's pretty much available online.
Old 22nd September 2013, 11:54 AM   #103
Originally Posted by 6L6 View Post
the important line in the short form spec is
AC Line Rated Class X1/Y2 Capacitors
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd September 2013, 11:56 AM   #104
You also need the correct joules to ensure you don't blow it up.
regards Andrew T.
Old 5th October 2013, 01:33 PM   #105
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Should I tie the grounds of both the positive and negative rail together for my F5? Looks like Nelson Pass did that on his power supply board: 6moons audio reviews: FirstWatt F5
CE-Designs.net
Old 5th October 2013, 01:42 PM   #106
JojoD818's Avatar
Yes you could do that as in the original F5 or you can tie the grounds on your star ground point too. Whichever one to do is left to your decision of course.
Old 5th October 2013, 01:55 PM   #107
Corpius's Avatar
thanks. As done in the original F5 is the easiest way, so that will do
CE-Designs.net
Old 5th October 2013, 01:57 PM   #108
JojoD818's Avatar
Indeed it is. Good luck and happy amp building.
Cheers
Old 5th October 2013, 04:21 PM   #109
jdg123 is offline jdg123  United States
jdg123's Avatar
star ground question: Is the concept to bring every ground from every board (even the single ended RCA input too?) to a single slab of copper?
I have some 1/8" x 3/8" bar stock that would do if this is the case...
P.S. I know the chassis gets a single ground at or near the IEC connector.
Old 5th October 2013, 04:53 PM   #110
roger57 is offline roger57  Canada
roger57's Avatar
Here's a picture of my DAC employing a single point ground using a #8 bolt with soldered ring tabs. Every PCB (or item) that requires a GND is returned to this point. Ideally, all grounds should be the same length as the purists will tell you. Have used this method in every piece of equipment I have made and I can tell you it's the best way to implement it. I cannot emphasize the importance of ensuring AC Line and Neutral connections are kept consistent and correct from transformers in each piece of equipment and between components to ensure the quality and safety of this approach.
BTW - the term "star ground" is typically used when describing PCB ground methods. When wiring a chassis, the ground point can be at any location as long as the "star points" (the wires) are reasonably close in length.
Universal Power Supply PCB Peter Daniel Audio Sector 75 7th April 2015 11:21 PM
ACA with Universal Power Supply bnorrish Pass Labs 4 24th November 2012 09:58 PM
Universal power supply board for audio amplifier siliconray Siliconray Online Electronics Store 11 13th February 2012 05:24 AM
■■■■Free Universal Power Supply Board For Tube Amplifiers ■■■■ siliconray Siliconray Online Electronics Store 2 10th January 2012 09:05 AM
My (almost universal) power supply Yoshy Power Supplies 0 7th September 2008 12:18 AM
Copyright 1999-2017 diyAudio
