F-5 Turbo boards - Page 6 - diyAudio
Go Back   Home > Forums > Commercial Sector > The diyAudio Store
The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Old 25th January 2014, 03:58 PM   #51
nashbap is offline nashbap  United States
It would be nice if much larger closeup pics of the store boards are posted at the store link. The small pics presently there are frankly quite useless and of no help especially to novices like me.
Thanks.
Old 17th March 2014, 05:36 PM   #52
sts9fan is offline sts9fan  United States
Could someone point me to what each test point on the store boards is for? I have the V2 boards I think.
Old 30th June 2014, 08:19 AM   #53
Default F5 V3 board question
Could someone please tell me:
1) What is C1 on the output board? Is this C3 in the NP schematic. Also from the pics it looks like there is a C2 on the output board. What is that?
2) What is the hole size for the +/- /G/OP holes on the output and FE boards? They look pretty small in the pics.
Thanks.
Old 8th November 2015, 05:00 PM   #54
mbrennwa's Avatar
What are the dimensions of the boards?
What's the minimum height required to mount the boards on the heatsink (include power FETs and diodes)? Will they fit on a 90mm heatsink?
(I'm not asking if such a heatink provides enough heat dissipation)
[ audioroot.net | hifibau.ch ]
"You have no clue of how an amplifier works." - AndrewT
Old 9th November 2015, 06:52 AM   #55
BigE is offline BigE  Canada
BigE's Avatar
Thanks.
The holes are ridiculously small. 14 awg will not fit.I drilled them out and used through hole PCB to wire solder cups to re-establish mechanical strength.
Old 12th November 2015, 04:54 PM   #56
mbrennwa's Avatar
I am confused about the PSU requirements described on the DIY-Audio store:
A stereo F-5T v2 requires a bipolar power supply of (+/- 32V). This will require an 24V+24V (or 48V Center Tapped) transformer from 600-800VA...
The F-5T v3 will require two of the above PSU. (One for each monoblock)
As far as I understood Nelson Pass' original article describing the F5-TURBO V1, V2 and V3, the improvement of the V3 over the V2 is the addition of the cascode, which allows using higher PSU voltages with V3 than with V2. So why do they recommend using the same PSU (and hence the same voltage) for V2 and V3?
Old 12th November 2015, 05:09 PM   #57
6L6 is offline 6L6  United States
6L6's Avatar
You may build the v3 with more voltage if you desire.
Old 12th November 2015, 05:13 PM   #58
mbrennwa's Avatar
Of course, I guess that's the whole point of the cascode.
But I'd like to understand the logic why they recommend using the same voltages for V2 and V3 in the DIY-Audio Store.
Old 12th November 2015, 05:17 PM   #59
6L6's Avatar
That was merely stated that way to illustrate that the v3 would most normally be built as monoblocks using the 5U chassis. So 2 PSU would be needed.
A few lines later it says that the amp can be built with higher voltages.
Old 18th November 2015, 06:45 PM   #60
Ezcl is offline Ezcl  United States
Would anyone be kind enough to provide physical dimensions of each PCB? I'm wondering if they are small enough to allow me to draw my own layout. (I will probably still order them from the store, I just really enjoy drawing boards.)
Thank you!
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
Turbo recone? djlivex PA Systems 0 23rd May 2012 02:52 AM
Turbo question Thawach Subwoofers 3 2nd March 2011 03:06 AM
E88CC turbo revintage Tubes / Valves 12 25th August 2010 11:52 AM
Zca ....turbo east electronics Solid State 9 10th April 2010 04:49 PM
Copyright 1999-2017 diyAudio
