F-5 boards - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > The diyAudio Store
The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Old 23rd November 2012, 09:18 PM   #21
Marra is online now Marra  United Kingdom
It might be worth reading cvillers blog
http://www.diyaudio.com/forums/blogs...version-2.html
Old 23rd November 2012, 09:30 PM   #22
labjr is offline labjr  United States
Originally Posted by jeffharr View Post
I purchased two of the V2.0 boards from the store, never dreaming that they wouldn't have provision to adapt to the latest schematic.
I understand that P3 isn't on the board, that's not an issue. The issue is being able to stuff the board from the most recent schematic on which the part numbers are different from the original, and the circuit has changes as well.
The store shows the original schematic, but does nothing to help this situation.
I want to build the most recent schematic but could sure use some help with an updated stuffing guide, otherwise I guess I should return the V2.0 boards and look for a more recent design?
Sure would appreciate some help with this; every other purchaser must face the same dilema!
Jeff
I bought the boards too, but haven't had a chance to figure which traces to start cutting. I wish I didn't have to hack up the boards.
I think the F5 circuit in the F5 Turbo manual is the most recent version. So the resistors on the input are different values and have to be reconfigured, The thermistors need to be moved from the rails to the points between R7-Q3 and R8-Q4. And P3 added.
Old 23rd November 2012, 11:17 PM   #23
JojoD818's Avatar
Jeff
The BOMs that correspond to that board has already the updated parts values. As you have noticed, the most recent iteration of the circuit has different part numbering, but the latest values have already been changed in the BOM. SO if you follow the BOM, you are actually building the latest version.
Old 23rd November 2012, 11:18 PM   #24
JojoD818's Avatar
Well worth the time indeed.
Old 23rd November 2012, 11:22 PM   #25
JojoD818's Avatar
The new values are already published in our BOM which is linked to from the product page. The location of the thermistors (one of it's leads) being on the transistor side rather than the rail side has of little to no difference at all in it's performance.
P3 can be added "off-board", but I was under the impression that one needs a distortion analyzer to perfectly adjust this. It wouldn't make any sense adjusting this by ear and everyone has this tool so maybe it makes more sense to leave P3 at the moment.
Cheers
Last edited by Jason; 21st December 2012 at 01:36 AM. Reason: Added bold for emphasis and a link for convenience
Old 24th November 2012, 12:23 AM   #26
Originally Posted by JojoD818 View Post
As I've said, the new values are already locked in the BOM. The location of the thermistors (one of it's leads) being on the transistor side rather than the rail side has of little to no difference at all in it's performance.
Cheers
Then why did Nelson change the circuit?
Cheers
So why even build the circuit then?
Old 24th November 2012, 01:14 AM   #27
JojoD818's Avatar
I believe it is so to take into account the voltage drop in the resistor.
I did say it has little to no difference at all because imho it is a minor "change the circuit" thing but I now realize this may mean the world to others and so it (the board) can still be configured to follow suit.
P3 was, as I understood it, added to completely minimize the effects of non-match jfets that may lead to distortion. Without P3, the amplifier still behaves and performs as published. It is therefore left to the builder if he/she will build it with or without P3.
Old 24th November 2012, 01:43 AM   #28
Part of getting the best sound out F5 and other amplfiers is tweaking for different amounts of harmonic content which make up it's characteristic sound. It's the small things that make a difference in the character. Otherwise we'd be better off building a chip amp. Solder one chip on a board and be done with it.
So to say it makes no difference, seems like you are not impartial because the boards you have here don't have those changes.
Old 24th November 2012, 02:18 AM   #29
JojoD818's Avatar
I meant the thermistor, not the P3. And like I said, P3 can still be employed easily by just bending the leads of the trimmer and soldering it on top of the board.
Old 20th December 2012, 05:05 PM   #30
Default F5V3
I hope the diyaudio store is not waiting to see how the Mayan thing unfolds before deciding to release the F5T V3 boards...
Do we have a tentative date on when these will be available in the store?
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
FS: F5 pcb boards sonidos Swap Meet 3 13th September 2010 04:41 PM
F5 assembled boards to sell DUC985 Swap Meet 0 21st July 2009 10:17 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright 1999-2017 diyAudio
