| The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store. |
#61 | |
- this has the inrush running through the CL30 - when the relay connects it shorts out the CL30 Is that safe? Is it effective and are there any benefits of replacing R15-R18 with a CL30? I am trying to decide if I should build this SS-board for an F5Tv2 with 1000VA and 200k uF caps. Thanks for all your contributions! |
#63 | |
though it can be done shorting the ntc out with a relay, i still say using fixed resistors such as that shown in the schematic is the way to go.....
http://www.elab.ph/forum/index.php?topic=32688.0 |
#64 | |
#65 |
Just built the softstart by the book, using:
C9 1uF C10 1000uF R15 - 18 180r 11w G5L 24V relay D13 24V 1w zener I am testing the build without load and the relay actuates very fast... half a second.... How can I increase the delay ? (Higher C10 ?) Or should I expect the circuit to work differently when connected to the power amp psu ?
RC |
#66 | |
#68 | |
you can series connect 2 x 1ufd caps... remember that C9 is your current limiter, the impedance it present to the line that is.... so that the zener current and the relay coil current added together is your required current after the rectifier.... Ohm's law is pretty much at work here.... ![]() TBH, i'd rather put a small housekeeping traffo in there, small enough to supply a few mA at 24volts...but it's just me....
#69 |
Correction... simulation with C9 100n and C10 1000u seems to work fine giving 4.5s to reach 24v. Th relay should work before that so I estimate it will close at 3.5s.... is it too much time ? Will it heat up too much the resistors ?
RC |
#70 |
so try 200nF...
| soft start power supply for dynaco st-70 | yero | Tubes / Valves | 9 | 8th July 2011 08:43 PM |
| Adcom 565 DED!!! Soft Start Board? | dracoskeeper | Solid State | 2 | 6th June 2010 04:29 PM |
| PCB Relay for ESP soft start board | wytco0 | Parts | 6 | 8th August 2009 08:23 AM |
| Blown 20watt 4.7uf on soft start board | ben62670 | Solid State | 4 | 26th June 2007 05:29 AM |
| Commercial Soft Start board | wytco0 | Parts | 0 | 5th August 2005 04:26 PM |
