Universal PSU, Capacitor and Diode Combination Board (V2) - Page 7 - diyAudio
Go Back   Home > Forums > Commercial Sector > The diyAudio Store
The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Old 27th May 2013, 12:04 PM   #61
News on the PCB availability ?
Old 1st June 2013, 08:37 PM   #62
Would love to purchase a couple myself.
Old 3rd June 2013, 06:14 PM   #63
any ETA on the PCB availability?
Old 5th June 2013, 08:10 PM   #64
ncg2013 is offline ncg2013  United Kingdom
Send a message via Skype™ to ncg2013
Default Capacitor soldering problems...
What size iron are people using to solder the capacitors to the pcb? I have 25 watt iron with 2mm bit and it seems to be a bit of a problem actually melting enough solder on the pcb pads for the capacitors. Takes too long and I am afraid I may damage the capacitors if I leave the iron on too long. What is too long 5 secs 10 secs?
Any advice appreciated.
Old 5th June 2013, 08:16 PM   #65
labjr is offline labjr  United States
I don't think a 25 watt iron will damage the capacitors. However, I started using a temperature controlled iron decades ago. It just works better.
Old 5th June 2013, 09:21 PM   #66
dimkasta's Avatar
The cap pads are big enough to make your life easier.
Heat only them until they pull the solder. Keep away from the cap' s wire, and only heat it directly when the solder has flown into the pad.
This should be a standard practice...
Second harmonic and wine for everyone...
Old 10th June 2013, 03:29 PM   #67
Small pads with narrow tracks will heat as quickly as leads on small through hole components. Here you can heat the pad and lead out simultaneously in about 2seconds.
Big pads with big tracks must be preheated with a well tinned iron until the solder melts on the pad. Only then should the iron be rolled, or slid, across the pad to touch the lead out to complete the joint.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 13th June 2013, 03:52 PM   #68
Boards anyone ?
Old 14th June 2013, 05:11 AM   #69
Boards ??????? You know what they say ? A picture of one is worth a thousand words, or may-be a thousand new orders !
Old 14th June 2013, 08:07 AM   #70
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
They'll be available for pre-order, along with schematic and pictures, within a few days. Probably Monday. Arriving in 45 days or so.
universal crossover prototype board nannoo Multi-Way 11 5th June 2013 11:24 AM
Universal PSU Capacitor Group Buy ncg2013 Power Supplies 0 5th April 2013 04:53 PM
15000uF 30mm Capacitor group buy for Universal PSU ncg2013 Group Buys 2 5th April 2013 09:01 AM
ZenV4 PSU, Nelson & Kristijan combination? Tazzy Pass Labs 7 16th October 2002 09:51 PM
Universal PSU ideas... stigla Everything Else 18 30th April 2002 01:03 PM
Copyright 1999-2017 diyAudio
