Universal PSU, Capacitor and Diode Combination Board (V2) - Page 5 - diyAudio
Go Back   Home > Forums > Commercial Sector > The diyAudio Store
The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Old 10th January 2013, 05:25 AM   #41
Electrons are yellow and more is better!
peranders's Avatar
Isn't 1-3 ohm a more correct value if you want to remove the parallel resonance?
Snubber guide lines
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 10th January 2013, 05:32 AM   #42
JojoD818's Avatar
Thanks, I have been using 10 ohms plus a 100nf cap for the longest time but if seems your studies show better performance with 1 ohm resistor.
Old 10th January 2013, 07:34 AM   #43
dimkasta's Avatar
Originally Posted by JohnGeneva View Post
I have only 10000 uf caps at 30 mm, can I place four larger caps under the board upside down . is there room to solder them in place as a way to increasing capitance?
I was thinking to do the same thing but the body of the caps is really close to the soldering pads. It might be dangerous for the caps, especially since we need to keep the iron there enough time to heat the pads.
Old 10th January 2013, 07:43 AM   #44
JojoD818's Avatar
Originally Posted by dimkasta View Post
I built a couple of boards for my F5 a few months back.
I have no big problem, except that they were not really designed to be used with heatsinks (as it was suggested as an option).
The holes for the secondaries and the jumpers are very close to the diode holes, so if you attach heatsinks it is really a PITA to fit the cables in there. And in some cases (like the jumper holes) the heatsinks sit right on top of them, creating mechanical problems and possible shorting issues
It is now clear that space for heatsinks to-220 diodes packages must be considered. Thank you for the feedback, we will consider your inputs in the next revision.
Old 10th January 2013, 02:29 PM   #45
perhaps I will try to add wires from the solder pads to some additional caps.
Old 12th February 2013, 10:31 PM   #46
ncg2013 is offline ncg2013  United Kingdom
Send a message via Skype™ to ncg2013
Default Using screw terminal caps off the board
I have the opportunity to get some 22000uf Kendeils at a discount but they are with screw terminals K61 TYPE. These will obviously not fit on the board, so does it matter if I just have leads running from the board to the capacitors mounted on the side of the enclosure? Anything to worry about?
Old 13th February 2013, 08:50 PM   #47
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
Then why use the boards??
" If you're going throu hell, keep going"
Old 13th February 2013, 09:15 PM   #48
Well, there are other components on the board, I do not have the experience to wire up without a board.
Old 14th February 2013, 02:04 PM   #49
Anyone else got a view? Anything to watch out for when wiring up capacitors of the board??
Old 14th February 2013, 02:22 PM   #50
dimkasta's Avatar
I agree there is no reason to use the entire boards if you plan to wire the caps somewhere else. You will just lose chassis real estate and run unnecessary lengths of wire.
Just snap and use only the rectifier parts. The resistors can easily be soldered or screwed straight on the caps
universal crossover prototype board nannoo Multi-Way 11 5th June 2013 11:24 AM
Universal PSU Capacitor Group Buy ncg2013 Power Supplies 0 5th April 2013 04:53 PM
15000uF 30mm Capacitor group buy for Universal PSU ncg2013 Group Buys 2 5th April 2013 09:01 AM
ZenV4 PSU, Nelson & Kristijan combination? Tazzy Pass Labs 7 16th October 2002 09:51 PM
Universal PSU ideas... stigla Everything Else 18 30th April 2002 01:03 PM
Copyright ©1999-2017 diyAudio
