diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   diyaudio.com Wiki (http://www.diyaudio.com/forums/diyaudio-com-wiki/)
-   -   Workhorse 1500W Bipolar Class H (http://www.diyaudio.com/forums/diyaudio-com-wiki/181257-workhorse-1500w-bipolar-class.html)
dfidler 16th January 2011 02:44 PM
4 Attachment(s)
NameWorkhorse 1.5KW Bipolar Class H Amp
TypeSolid State
ApplicationPA
ClassH
Approx CostUnknown
DesignerWorkhorse
Threadhttp://www.diyaudio.com/forums/solid...r-class-h.html
The Project
Do it yourself, Class-H power amplifier 1500WRMS @ 2ohms
Introduction
Its a Class-H amplifier with following features:
1: Fully complementary symmetry input differential with Cascode loading.
2: CE-CB Cascode VAS for wider bandwidth.
3: 2 Step rail switching with controlled slew for minimizing switching noise.
4: Triple EF output stage for high damping factor and ease in 2 ohms load driving.
5: All set of required basic professional protection circuitry.
6: Almost Half the heat dissipation of same wattage class-ab amplifier due to Rail Tier Switching and excellent handling of reactive loads.
Goals
Goal: To design a reliable amplifier with professional standards.
Result: All design goals met.
Specifications
NameDescription
Voltage Gain26dB
Full power Bandwidth20-20kHz
Power output1500WRMS @ 2ohms
Input Sensitivity4Vrms @ 8Ohms
S/N Ratio100dB
Peak Consumption4400VA @dual channel @ 2ohms continuous music operation
Idle Consumption110W
Harmonic Distortion0.05% THD [FPRL]
Load Impedance2 ohms minimum
Slew Rate33v/uS
StabilityUnconditionally stable with all known real world speaker loads
Output configurationsParallel/Stereo/Bridge operation
Damping Factor>1000 @ 100hz
Additional Features
* Thermal shutdown
* DC Fault
* Muting
* Short Circuit Protection
* True Clip Detection
* Signal out
* Fault Status
Schematic/Blueprint
http://www.diyaudio.com/forums/attac...1&d=1295337939
Bill of Materials
There is no BOM just yet. Will be added later.
Simulations and Analysis
<Embed the images for your simulations here along with descriptions for each of them so people know what you're talking about.>
Construction (Steps / Tips / Notes)
Project Files
The files for this project are available in the attachments section at the bottom of the page.
Other Notes
* Requires 2800VA transformer with following winding specs: 85-50-15-0-15-50-85 14A secondary.
* PCBs should be printed with minimum 35micron and PTH is must as there are vias on the board
* PCB measures 37 X 12 cm (4.75 x 14.5 in)
* Bias Pots: 10mV across emitter resistors of output devices corresponds to 30mA through each device, should be optimum
Known Substitutions
* You can use Genuine 5200/1943 upto 1.5KW or MJL21196/95 for 2KW
Reviews
No reviews yet...
Build Threads
Examples:
Have you built this project? If so, please add the URL to the thread that you started to show off your build.
  • URL to my uber build 1 thread
  • URL to my super dooper build 2 thread!!!
  • Thread 1234
  • GroupBuy:PSU
Workhorse 16th January 2011 04:31 PM
Nice Try .........!!!
Poisonspy 16th April 2011 11:57 AM
Thanks Workhorse,
I am looking forward to make one.
Your guidance expected.
masood 21st April 2011 04:04 AM
1.5kw bipolar amplifier pcb
it is good circuit i,ll try to make it. plz send me the part list also.
thanking you.
os12300 31st August 2012 11:23 PM
My best regards and Thanks Workhorse, this power amplifier is OK!!.
Andres from Veracruz Mexico.
Workhorse 19th November 2012 02:58 AM
Cheers....!!!
Resources saved on this page: MySQL 17.65%
