Amp Camp Amp #1
Amp Camp Amp #1
Closed Thread
Old 22nd November 2017, 07:47 AM   #51
kking85743 is offline kking85743
Originally Posted by kpsthakur View Post
Any sneak peek (maybe a blurred view) of the new board?
Sure... but it's not terribly blurry...
The blue scribble over the AMP in AMP CAMP 1.1 (lower left corner) is to help me keep track of the blue board vs the red board. The MOSFETs are about in their proper place on a 2Ux300mm heatsink (orig. ACA boxen used a 2U200mm heat sink) and numbered to keep track of parameters. The white block on the right is a 3D printed part that fits in the gap between the fins and will allow me to put a hole precisely in the proper place (for mounting the MOSFETs). The board will be mounted on the base-plate.
300mm x 80mm of 40mm fins is probably overkill for the ACA, but if it's worth doing... it's worth overdoing!
Please note that these were going at fire-sale prices (appropriate for Burning Amp, right?) because they were going to do another turnaround on the layout before being offered as a product, so the "official" version (v1.2 perhaps?) may look different.
Old 30th November 2017, 10:28 AM   #52
kpsthakur is offline kpsthakur  India
Thanks, is there a red board too...schematics?
Old 1st December 2017, 05:46 AM   #53
Not sure about a red board (I call one the red board and the other the blue board (rather than naming them) just to keep track of parts, values and tolerances, as both are identical green circuit boards), but there appears to be more than one board layout bearing the ACA 1.1 moniker, so who knows. The photo is of the ACA 1.1 which I got at Burning Amp 2017, about a month ago.
The schematic for the ACA 1.1 (as presented at Burning Amp 2017) can be found here:
Burning Amp 2017 Updates Thread
Look at the second image in post 65, complete with the person of Nelson Pass pointing at the screen/schematic
Hope that helps.
If you were interested in ACA 2.0 (or ACA, the next generation, or whatever they decide to call it), see post 15 in this thread:
Questions about amp camp amp and linear power supply
Happy hunting/building!
Old 17th February 2018, 05:04 AM   #54
ThermalAlchemy is offline ThermalAlchemy  United States
Default IRFP240 out of production and out of stock everywhere
at Digikey this came up as a replacement
Electronic Components and Parts Search | DigiKey Electronics
IRFP240PBF-ND will this work ?
im late to the AMP building party and missed out on the ACA kit.
Old 8th May 2018, 03:13 AM   #55
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
Amp Camp Amp #1
Please continue discussion of the Amp Camp Amp over here: Amp Camp Amp - ACA
Closed Thread
Amp Camp Amp #1Hide this!Advertise here!
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
