Old 8th February 2012, 05:57 AM   #11
putko is offline putko  Finland
Hi
Michael Rothacher mentions in L'Amp CCS Addendum that
"So, I tried (D). It uses a self-biased IXYS depletion mode MOSFET
IXTH6N50D2. "
That beast is not easily available (at least in Finland). Could somebody say, is there anything special in IXTH6N50D2 (irreplaceable), or can it be replaced with some other bug (I understand semiconductors but cannot evaluate them)
Best wishes HPu
Old 8th February 2012, 06:01 AM   #12
Question Replacement for IXTH6N50D2
Hi
Michael mentions in "L'Amp CCS Addendum" that "So, I tried (D). It uses a self-biased IXYS depletion mode MOSFET IXTH6N50D2. "
The IXTH6N50D in almost impossible to buy. Is there some other bug that does its work
Best wishes HPu
Old 7th December 2012, 01:36 AM   #13
Garuda77 is offline Garuda77  United Kingdom
Could anyone suggest the correct/minimum size/value for the CSS heatsink please? also @ putko found this:
IXTH6N50D2 IXYS | IXTH6N50D2-ND | DigiKey
not sure if they ship to you though?
Thanks Terry
Old 7th December 2012, 10:03 AM   #14
Hi All
I just want add this fact to IXYS and Europe. I found out that they have an importer in Swizerland. When I asked them how to get one pair of IXTH6N50D2.
They said it's ok. Minimum ordes is around €200. When I explained the story (I would like do some testing for myself)m, they organized the thing that I could purchase one pair with normal sneding costs. This was well below €200.
So all kudos (praise!) to this company's representatives in Europe.
best wishes HPU
PS
This is meant to be helpful, if somebody else is in the same situation, when I was.
PPS
For various reasons I have not had oppoturnity to build the thing.
Old 25th April 2014, 05:11 PM   #15
johnyradio is offline johnyradio  United States
hi Michael, can your addendum version run on batteries?
thx
Old 1st November 2016, 08:59 AM   #16
Aboulafia is offline Aboulafia  France
A similar idea of one transistor amp was presented in the french "revue du son" some years ago. The active part was a more common 2SK135 (which has pentode like curves) with drain to grid feedback, that made it behave like a triode. Different circuits were built using this method, some based on the NEMESIS amp.
This very simple topology is well suited to high impedance headphones for instance.
Old 13th April 2017, 10:04 AM   #17
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Michael,
you mention a hefty bump possibility when turning on off. Is that due to the inductance?
How about a diode across the choke (inverse)? This is done with solenoids. == or one in series. So no energy goes to the power supply. I have seen this in tube amps. Only for the turn-off bump, to prevent Tesla's energy spike from developing.
just a few .
I have a pair of TO-3 SITs and I am sitting on them. And I have huge 110 mH multitapped chokes.
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 13th April 2017, 11:13 AM   #18
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
I said doesn't have a significant turn-on thump. Have fun
Visit AudioMaker.Tech
Old 13th April 2017, 11:57 AM   #19
triode_al's Avatar
Michael,
In fact this is what triggered me:
NOTE: The author suggests that you should always have a speaker or dummy load connected when powering the amp on and off.
I shouldn't mess around with designs. albert
Old 13th April 2017, 12:11 PM   #20
AudioMaker.Tech
Nothing to do with bump. I was addressing the accidental omission of a bleeder resistor in the drawing. Here's the entire quote:
NOTE: The author suggests that you should always have a speaker or dummy load connected when powering the amp on and off. Furthermore, you may wish to install a 200 Ohm, 3 Watt bleeder resistor from output to ground to safely discharge the coupling capacitor in case you should forget the foregoing.
I don't think your music would appreciate the diode. Have fun
L'Amp: A simple SIT Amp ra7 Pass Labs 2919 10th May 2018 06:00 PM
LAmp: A Simple SIT Amp: Part 1 Michael Rothacher diyAudio.com Articles 23 1st September 2014 01:02 AM
