What is Gain Structure?
Old 2nd April 2016, 01:25 PM   #111
bobdoh is offline bobdoh  United States
Hi Guys!
Many thanks for the help!
Andrea Ciuffoli (thanks)
I went to his site and found his paper on his
"Power Follower 99" a solid state class A amp 30wps at 6ohms
He also says
"The presented topology, has NO gain (actually it looses something) and should be preceded by voltage gain stage, with an output swing not lower than 10Vrms and Rout < 1000Ohm. "
This sounds perfect! Can this zero gain amp be implemented DIY or is it too esoteric and should be purchased from a person like Ciuffoli?
Old 2nd April 2016, 01:51 PM   #112
R.I.P.
Ciuffoli Power Follower(Buffer) has very few parts and could be done as hardwired.
A gain of 1times is equal to +0dB = -0dB
A gain of 0.99times is equal to -0.09dB
If you preceded the Power Follower with a very low gain pre-amp stage like switchable between +0dB, +6dB and +12dB, you could probably drive the output to maximum power with most of your sources.
Possibly BA 3 pre, or Juma, or many others.
regards Andrew T.
Old 2nd April 2016, 04:19 PM   #113
Hi Andrew
Many thanks for your help. I understand conceptually what I need - I just lack any technical ability to build. Are there people that will build these custom for a fee?
If you had a generous budget which of the pre-amps you listed would you recommend (given a zero gain amp)? (should it be dual mono?)
On the zero gain DIY amp - is there a Honey Badger equivalent of a zero gain design out there that can be used?
Thanks again
Old 2nd April 2016, 06:15 PM   #114
R.I.P.
If I didn't need pre-amp gain then either a B1 or a DC B1.
If a bit of gain is required, then probably a Juma.
regards Andrew T.
Old 22nd March 2018, 02:08 AM   #115
Telstar is offline Telstar  Italy
Originally Posted by Telstar View Post
Now the issue is where to attenuate. Doing it at the power amp imput is NOT the ideal solution, the best option would be to adjust the gain of the amp itself (like Ayre and ASR do).
The ideal gain structure would be
2-2,5V from digital source -> input buffer -> adjustable VAS from like 0,1x to 20x (to provide for less efficient speakers) -> unity current gain.
And after 6 years nobody made a DIY circuit that realizes this...
Addenda: if we do NOT employ GNFB, stability shouldn't be an issue.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
What is Gain Structure?Hide this!Advertise here!
help on amp gain structure nicoch58 Tubes / Valves 3 16th December 2010 11:09 PM
S/PDIF data structure billbo Digital Line Level 4 14th October 2008 12:16 PM
6M6G Structure of the circuit RCA245 Tubes / Valves 2 11th April 2005 05:51 PM
Anybody know anything about this kind of motor structure? 454Casull Multi-Way 2 3rd August 2004 12:40 AM
