His Master's Noise: A Thoroughly Modern Tube Phono Preamp
Old 24th July 2010, 04:37 PM   #41
sonidos is offline sonidos  United States
Libertador de la Música
sonidos's Avatar
I live approximately six miles from SY and after several months, we finally had time for personal introductions and I spent a rewarding evening listening to SY's 'Noise'. We got down to business right away. We switched liberally between CD and vinyl. Fortunately, no brain probes were involved. Lucky me!
If anyone has inquiries regarding buzzing, hissing, humming, or downright rude noises coming from his concoction, let me lay all doubts to rest. It was quiet. VERY quiet. Now I did not go to the speakers and lay my ear next to either one, but I never listen that way!
So I ended up having to fight the urge to drool because the music was very enjoyable and SY can attest that my full attention was on the music. In conclusion, I will do everything in my power to convince SY to finish his MM version. My guess is that it would make some great noise in my personal system!
Thanks, SY for the invitation!
Old 24th July 2010, 05:35 PM   #42
On Hiatus
SY's Avatar
Delighted to have you over! Having Stevie Ray Vaughn albums tucked under your arm was a sure sign of class.
Your Rega will be a perfect guinea pig (non-Peruvian) for it.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th July 2010, 05:57 PM   #43
Pano is online now Pano  United States
Pano's Avatar
They eat Guinea pigs in Peru, so be careful!
Old 24th July 2010, 07:19 PM   #44
sonidos's Avatar
I know Pano! My wife is Peruvian.
SY just wants my ears and the audio interpreter between them. gulp!
Old 12th October 2010, 03:03 AM   #45
jackinnj is online now jackinnj  United States
jackinnj's Avatar
I'm thinking something like this -- the board splits in half (use your band saw or some aircraft snippers):
Old 20th October 2010, 03:32 AM   #46
jackinnj's Avatar
Default On a PCB
Here's HMVS on a PCB -- the Sowter trafos not yet mounted:
Old 22nd October 2010, 11:16 AM   #47
Skorpio is offline Skorpio  Denmark
Very nice article, thank you!
Any reasons for using the output buffer instead of taken the output from the source of the lower DN2540 at the CCS second stage?
Old 22nd October 2010, 01:03 PM   #48
On Hiatus
SY's Avatar
That's another valid design path which I didn't explore. I like esthetically to use tubes exclusively as the signal amplifiers in this design, there's an extra tube section available, and I've had great luck with ECC88 cathode followers. But one might get an equally excellent result using (effectively) a source follower. The downside is that it reduces the effective plate load, though I suspect not enough to materially affect the circuit performance (haven't measured or simmed the effect of the load shunting the source to ground).
Old 22nd October 2010, 01:08 PM   #49
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
SY, I was surprised about how dead quiet this thing was last night, combined with the tube headphone amp I brought. I cranked the thing with the needle up and couldn't hear a thing over the din of the party. Amazing!
Old 22nd October 2010, 01:12 PM   #50
On Hiatus
SY's Avatar
Unfortunately, the headphones you left here totally spoiled me. I had been getting by with some cheapies but now... dammit.
Your 'phone amp sounds excellent, BTW. I will need to study this at length.
His Master's Noise: A Thoroughly Modern Tube Phono PreampHide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
noise planarboy Analogue Source 2 11th February 2008 08:06 AM
Still have noise. pjanda1 Chip Amps 40 17th March 2006 03:16 PM
Help with noise davidlzimmer Chip Amps 25 5th March 2006 09:39 PM
Noise Bukitoo Analogue Source 2 17th March 2004 02:37 PM
Copyright ©1999-2017 diyAudio
