His Master's Noise: A Thoroughly Modern Tube Phono Preamp
Old 21st April 2010, 07:56 PM   #11
On Hiatus
SY's Avatar
Well, a shunt regulator is a preferred choice for circuits where PSR has been traded off for gain or linearity. In this case, because of every stage being CCSed to the max and the plate impedances being very low, the PSR is outstanding and the limitations are not in the regulator.
dh, I don't have data on that configuration, but it certainly may be worth trying. That does reduce the source impedance of the CCS (as seen by the tube), but how much and how serious I just don't know. Nor do I know the sonic effects, if any. I'd be interested in your results if you do that.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 21st April 2010, 08:24 PM   #12
jlsem is offline jlsem  United States
jlsem's Avatar
Very nice article, but I'm confused. Has it really been online for a month and I just missed it?
John
Old 21st April 2010, 08:30 PM   #13
On Hiatus
SY's Avatar
Are you using aluminum cookware?
Old 21st April 2010, 08:35 PM   #14
jlsem's Avatar
No, but I'm sure the spoonfuls of live-monkey head cheese isn't helping.
Seriously, though, the article is dated March 21, 2010. Admittedly, I don't spend much time in the articles section.
John (Cookware? What's cookware?)
Old 21st April 2010, 11:50 PM   #15
gingertube is offline gingertube  Australia
Page 4 - Mate!!
"So for example, suppose one has three uncorrelated noise sources in series of 1mV, 0.5mV, and 0.1mV. The total equivalent noise voltage is then √(12 + 0.52 + 0.12) = 1.12mV."
Right answer BUT wrong expression.
I did a random sampling maths checks and did'nt see any other "clangers".
Ian
Old 22nd April 2010, 12:29 AM   #16
Sheldon is offline Sheldon  United States
Regarding the mu follower. I'm cooking up this project: pentode buffer
I was planning a cathode follower stage, but decided for a few reasons that the mu follower on the output tube would work out better. Will probably make it a gyrator, though will probably try both.
Salas, you may recognize certain elements.
Sheldon
Old 22nd April 2010, 12:57 AM   #17
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes. Good research.
Old 22nd April 2010, 04:28 AM   #18
On Hiatus
SY's Avatar
Ian, the superscript tags got lost. All those trailing "2s" should be superscripted (squares), i.e., 1 squared + 0.5 squared + 0.1 squared. That's why the answer worked out correctly. I'll fix that tomorrow. Thanks for the close reading.
Old 22nd April 2010, 05:55 AM   #19
grufti is offline grufti  United States
grufti's Avatar
Great reading, even better amplifier.
The numbering of the figure captions way at the end of the article on page 14 in messed up, not that it matters much. The table of contents numbering [repeated on every page top right] is also interesting in that it is single digit only and starts repeating at 10 [or zero, if you are so inclined].
Old 22nd April 2010, 01:26 PM   #20
Pano is offline Pano  United States
Pano's Avatar
Very nice SY, bravo!
I think I might like to hear Brubeck's version of "These are a Few of My Favorite Things" played thru it. Why? Cause you put in a few of my favorite things. =)
  • Balanced, transformer input
  • Passive RIAA
  • Output buffer
  • A neon tube!
I've never understood why most phono cartridges are not run balanced. It seems a natural. Mics are...
Only ever built one tube phono preamp and it was passive RIAA, I loved it.
One thing I would love to see is a MM version of this. Not all of us are brave enough to use MC carts, but we MM guys could use a good input stage, too.
Perhaps a "Voice 2000"? (a pun)
Take the Speaker Voltage Test!
His Master's Noise: A Thoroughly Modern Tube Phono PreampHide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
noise planarboy Analogue Source 2 11th February 2008 08:06 AM
Still have noise. pjanda1 Chip Amps 40 17th March 2006 03:16 PM
Help with noise davidlzimmer Chip Amps 25 5th March 2006 09:39 PM
Noise Bukitoo Analogue Source 2 17th March 2004 02:37 PM
