His Master's Noise: A Thoroughly Modern Tube Phono Preamp
Old 23rd August 2012, 10:11 AM   #131
On Hiatus
SY's Avatar
Drew, I can't seem to find an inductance and DCR spec for your cartridge. Do you know it offhand?
My drawings were done with ExpressSCH freeware. There's better out there, I just am incompetent.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 23rd August 2012, 10:27 AM   #132
PET240 is offline PET240  Australia
Hey Sy,
Not offhand, will ask Mr Gregory....
Will have a geezer at ExpressSCH, they don't look incompetant, they work, that's enough!
Thanks again!
Old 23rd August 2012, 11:04 AM   #133
Sy,
Will advise when I receive response, have also asked why capacitance has no effect.
Now to find libraries for tubes etc for expressSCH.
Thanks for the heads up!
Old 8th September 2012, 03:12 PM   #134
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I wonder if the filament regulator input bypass capacitors (C12,16 0.1uF) aren't better connected to the Chassis ground, rather than the heater common.
Old 1st November 2012, 11:48 PM   #135
rrrs is offline rrrs  United States
Hi SY, just completed your phono amp using DIY-tech boards! Was able to pack all together in single chassis including the power transformers; with shorted inputs it is perfectly quiet; a bit of hum when connected to the cartridge; have to try twisting the wires from input RCA to the board.
Really impressed with the sound, thanks for making this project public!
As well, thanks to Jack for making the PC boards!
I am using SAE 1000E HOMC cartridge, no input transformer, just 47K resistor on input.
SAE spec is: 2.5mV output, Load impedance: 47K (non-critical), Load capacitance: non critical; it was apparently made by Coral.
Two things I found strange:
1) From 4 D3a tubes, with CCS adjusted at 20mA (there is 19.8V drop across 1K plate resistor) I got huge plate voltage variations between the tubes: 140V, 163V, 179V and 199V! Did you maybe get simmilar experience? Should I buy some more D3a’s to be able to find two that are more similar?
2) My 160B+ is spot on, at 160.5V, but second B+ instead of 260V is 210V; it is all the same on both channels; my unregulated HV is at 339V. Do you think I should tweak the 260V regulator to get closer to 260V or 210 should be fine?
Old 2nd November 2012, 01:47 AM   #136
On Hiatus
SY's Avatar
Yeah, there's a lot of variability in D3a, but 163 and 179 isn't too bad.
I'd want to get the B+ up a bit, maybe 220-230V minimum.
Old 2nd November 2012, 09:35 PM   #137
Thanks, will get my B+ up, closer to 260, as you sugest. I checked all resistors in 260V regulator and they are alll correct; really strange I am getting only 210, especially since 160 regulator is spot on.
Would you mind sugesting resistor values to adjust to get up from 210; I guess R25 and R26 would set the output voltage, but please, if you could help a bit with right way to calculate actual values.
Old 2nd November 2012, 10:19 PM   #138
On Hiatus
SY's Avatar
You might want to look closely at the error amp transistor and the voltage reference. Could you measure the voltages at EBC of both transistors on the oddball channel?
The circuit functions as a basic feedback amp. The reference diode is the noninverting input, the two resistors from output to ground form the feedback voltage divider. I don't remember their numbers offhand, but let's say that the upper one is R1 and the lower one is R2. Vout(R2/(R1 + R2)) = Vref + 0.7V (the Vbe drop of the error amp).
Old 2nd November 2012, 10:52 PM   #139
OK, thanks, so it makes sense:
On 160V regulator I got 160V(8.2K/(160K+8.2K))=Vref+.7V; Vref comes to 7.1V; very close to nominal 6.9V for LM329.
On 160V regulator I got now 210V(8.2K/(220K+8.2K))=Vref+.7V; Vref comes to 6.84V; very close to nominal 6.9V for LM329.
In order to get 260 I could adjust R2 to 6.6K to get 260V(6.6K/(220K+6.6K))=Vref+.7V; V ref comes to 6.87V; very close to nominal 6.9V for LM329.
I will parallel my 8.2K with 51K I got here; this should do the trick!
Old 2nd November 2012, 10:53 PM   #140
Sorry, did a type, second equasion was supposed to be:
On 260V regulator I got now 210V(8.2K/(220K+8.2K))=Vref+.7V; Vref comes to 6.84V; very close to nominal 6.9V for LM329.
His Master's Noise: A Thoroughly Modern Tube Phono PreampHide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
noise planarboy Analogue Source 2 11th February 2008 08:06 AM
Still have noise. pjanda1 Chip Amps 40 17th March 2006 03:16 PM
Help with noise davidlzimmer Chip Amps 25 5th March 2006 09:39 PM
Noise Bukitoo Analogue Source 2 17th March 2004 02:37 PM
Copyright ©1999-2017 diyAudio
