Go Back   Home > Forums > General Interest > diyAudio.com Articles
Comment
Article Tools Search this Article
Old 21st April 2010, 12:00 PM
SY's Avatar
Default His Master's Noise: A Thoroughly Modern Tube Phono Preamp
After more than 25 years of faithful service, it seemed that it might be time to redo my phono system. After all, I like to think that I've picked up a few tricks in the intervening years... The old system consisted of a VPI HW17-II, a Linn Ittok LVII tonearm, and a Troika cartridge. The Troika was...
13th March 2017
6L6's Avatar
6L6
Herman,
He's designed it, "The Equal Opportunity"
Published in Linear Audio in two parts - 1) https://linearaudio.net/article-detail/2170 2) https://linearaudio.net/article-detail/2206
And here's the diyAudio thread - "Equal Opportunity" MM Pre
I'm building one, slowly. You have to get the articles from Jan. There might be a set or two of PCB still floating around.
13th March 2017
noviygera
6L6, thank you!
13th March 2017
Freecrowder
Are boards for purchase available from someone on this project? Is it one board or multiple boards? Thanks in advance.
13th March 2017
cogeniac
I am building the EO preamp as well. I decided to do my own boards because of the physical layout I wanted. So, I have the signal components and the CCS's on two identical boards with the tube sockets on the opposite side from the components (so the tubes can protrude through holes in the chassis), and I have the power regulator circuits on a separate board that is mounted a couple of inches away in a vertical setup so the big regulators all have convection cooling. The chassis top and vertical section is done with mirror finish stainless, so the tubes will be nicely showcased. The rest of the "chassis" is varnished teak, and there is a perforated cover to protect the supply while allowing for convection cooling. It is about 90% done.
I started by collecting parts for the HMN preamp, and then, like noviygera, realized I wanted to do an MM design. So, the power transformer I had was wrong (too high a secondary and no separate tap for the negative supply. I built it up anyway thinking that Sy's statement "the higher the better" in terms of regulator overhead would save me, but then I realized that later in his article he pointed out that at 16 mA, the overhead can't be too high before the heat dissipation in the regs becomes too high. Edcor does make one that works, but it is a special order. Not too expensive, but 6 week lead time!!! This modified raw supply should produce about 165 volt B+ rail, and an 18 volt B- rail.
I'll post pics of the build in a few days.
Scott
13th March 2017
lehmanhill's Avatar
lehmanhill
Herman,
SY is on a vacation from diyAudio. While not speaking for him, what SY did do was design an MM phono preamp. There are two articles in Linear Audio volumes 7 and 8 for the Equal Opportunity MM Phono Preamp. There is also a thread here in diyAudio started by jackinnj.
I found it very interesting to read both the "Majesty's Noise" and the "Equal Opportunity" because he clearly explains his design philosophy and the differences in approach between the MC and MM.
It takes some looking, but I found I could buy just the articles from Linear Audio on their website.
By the way, I'm one of the guys that built the EqOpp preamp and love it.
Jac
13th March 2017
cogeniac
Here are my boards for the EO preamp. I'll start a new thread on this so we don't drift this one.
As noted, I put the tube sockets on the top of the boards, and put the components on the bottom. This allows me to have the tube sockets poke through holes I cut in the stainless top plate of the chassis, and allow room for the somewhat large components. The tubes will thus show, while the boards won't.
Once I test this, I'll post the board artwork so that anyone can get the boards fabbed. They were pretty expensive in small quantity (about $60 each), but they are very nice quality. I did the layout in Eagle. Signal boards on the right, regulator on the left..
Scott
13th March 2017
lehmanhill's Avatar
lehmanhill
Scott,
Nice design. I get what you are trying to do. The advantage of the way that SY designed it is that he can use the input boards for other projects.
Jac
Comment
Search this Article:
Article Article Starter Category Comments Last Post
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
noise planarboy Analogue Source 2 11th February 2008 08:06 AM
Still have noise. pjanda1 Chip Amps 40 17th March 2006 03:16 PM
Help with noise davidlzimmer Chip Amps 25 5th March 2006 09:39 PM
Noise Bukitoo Analogue Source 2 17th March 2004 02:37 PM
Copyright 1999-2017 diyAudio
