#321 |
Maks i guess some people just can't read thats to easy!!!READ THE FORUMS PEOPLE!!!By the way maks I've started another build the final one I HOPE!!This one is going to be using a 15"LCD T.V with much higher resolution better contrast and faster response time.With the current setup the furniture is placed to close to the projected image with little room for comprise and therefore i would like the image in HD.(sharper,clearer,brighter,more contrast,etc.)Now that i no how to build this one will be a breeze. http://www.hostclip.com/dl/4a667dece...63714043285442
Projectors Rock!DIY all the way. |
#322 |
Here is another pic this is the light setup!!http://www.hostclip.com/dl/7aedfa316...b33ede3cadbad2
#323 |
Here is one of my on screen guide!!!http://www.hostclip.com/dl/05a92e8ad...614bde8e8e6712
#324 | |
btw, I dismantled my PJ today..... had to take off the ballast, it needs to be replaced... that damn thing doesn't fire the bulb soon. Also, I'll soon start working on a LED matrix on experimental basis.... if it takes off, the MH and accompanying heat will be eliminated. But as I said, it'll be experimental... dunno how the color temp. and other things wud be. |
#325 |
Maks that is unfortunate that your ballast has give up NOT GOOD!!As for the Led setup good idea that has been done before less heat yes by far the best way to go !Color temp can be solved that has been proven.Production NOOO way !!!I just want an awesome projected image HD is the way to go.So that is the way i will go!I have also started my theater. It is going to be portable so that when i move April 15th i can then set it up even better!Looking forward to this weekends wrestle mania on giant screen.Hurrayyy!!!
#326 |
i cant resist my temptation to post this url. its simply wonderful. difference between white wall and gray screen. great DIY. but my question is there any equivalent code for paint available locally here (INDIA). we can easily get polyvinlyl(hoarding sheets). but what about other equivalent stuff. we guys make some market research on paint.
http://www.avsforum.com/avs-vb/showthread.php?t=708009 http://www.avsforum.com/avs-vb/showthread.php?t=776981 @Mods: sorry if i pointed external link in this forum. |
#327 |
@Maks: i remember u are using polyvinyl. how is the performance and what will be the cost 100 inch diag.
#328 | |
well yes, I'm using a Polyvinyl cloth for screen.... Cost I dunno... one of my frens who does laser printing jobs gave it to me for free... I have painted the back of the screen with light grey paint... U can see the difference for urself on my website. pls follow these URLs Before making the screen (pls scroll down for results pics) http://macxpages.tripod.com/id5.html After making the screen (Poly Vinyl) http://macxpages.tripod.com/id13.html |
#329 |
thanks for the reply maks..
Is that osram power Ball?. then tell me the part number of the lamp and how much does that cost and the cost of the ballast too. seems like there is some screen door effect in the screen. what is the native resolution of the display |
#330 | |
and yes... mine is a OSRAM power ball MH lamp. The part no. is 150W/830 WDL HCI-TS. It did cost me a bit more here in B'lore. The bulb alone is 650/- re. With ballast and fixture, all came in for 1900/- re. |
| Page generated in 0.13832 seconds (78.95% PHP - 21.05% MySQL) with 11 queries |
