#121 |
Hi rensenin,
Iam basically from madurai but currently living in colombo. I whould suggest you go and look around for those LCD TVs that are ment for cars (7"/8"). If you know any OHP service centers then you can get some lens from them too. You can also try lensel from pune (yet to get a reply for my email ).Actually it all depends on your budget.... All the best and have fun. |
#122 |
thanks ilango,
will defnitely check out with lensel in pune. hows yours coming up. did you happen to complete it. Can you send us some pics of your projector |
#123 |
Mine is not ready yet. Have to import almost everything here
Trying my best to get as much as possible locally... As of now I have only the LCD ready and stripped. I have an 9" from a laptop and a Benq 15" both ready for the proj. If I can replace the hard disk of the laptop my proj will have a builtin computer
#124 |
hi budhi
i am very happy for your projector you made i am very much interested to made projector but i don't know where to get ohp freshnel lense and projection lense. basically i am from faridabad DELHI NCR. so pls help me to get these items. regards harish |
#125 |
Maks0001, How is your projector ??? Any updates??? Iam still not getting any reply from Lensel !!!!
#126 | |
#127 | |
#128 |
Maks, not sure when businessman like the ceo of lensel will wakeup to the online business. If they can have a website and an email address how difficult is it to reply an email?????
I think I will order them at 3dlens. |
#129 |
Hi Maks, I Think I can solve your Problem of wavy lines.
Lets go step by step! 1. make sure your project is grounded well >A three pin plug is a must for all projectors. If you are using a wooden cabinet then you need a sheild of some sort around your metalhallide switchgear (perforated metal casing) this unit like any tubelight ballast (choke) emits a lot of interference which can give you wavy lines. 2.The powersupply for the Lcd screen should be isolated from the lightsourse by powerline filters. an easy way to do this is if your lcd screen uses a 12V power adaptor dump the one that came with the screen and get a 12V adaptor meant for scanners these have a built in fuse and line filter just near the point that goes into the unit. this filters out most of the powerline irregularities. 3.Like in all audio and video projects sheilding the signal is very important get good quality connectors and cables that do not pick up interference. Your projector is almost done, as you say you can see a clear picture when you use a torch for the source, its your lightsource hum and noise being picked by the LCD they are extremly sensitive to this, so sort out these few things and rock on . Hope this helps bro. |
#130 |
Thanx a Tonne, Budhi.... I must appreciate your help and the systematic approach. So, let me too reply in the same order.
1. Being from the Electronics background, I have always known the importance of Grounding and sheilding. My projector is does have a three pin plug and is grounded well. Yes, I am using a wooden cabinet and the lamp is fitted inside the metal enclosure (please see the attached pic). 2. As you can make out from the attached snap, my PJ is a folded design. It has lower and upper partitions. I have mounted all the power supplies in the lower partition and all electronics in the upper partition. But yes, I can give it a try by getting a scanner PS as you have suggested. 3. I have used the best available connectors for signal inputs. They are gold plated and has cost me a good amount of money. The cables too are good quality shielded cable and I have taken enough care to cover the solder points. But anyways, I think I will give it a second shot and emphasize on the points that you have recommended. Thank you once again... will bug you if I need any further help. |
