#1281 |
hi.......srinishare, where to buy you triplet lense. plese give me website address.
#1282 | ||
I bought it from Optolife Optolife - optics manufacturer: OHP lenses, projection lenses, triplet lenses, diy projector, aspheric condenser lenses, reflectors, front surface mirrors, heat filters, frenel lenses You will be more than happy to see they have so much variety of lenses. ![]() Here is the excerpts from the email communication where I paid through western union money transfer. Quote:
#1283 | |
hi lovekesh i am also from chandigarh and yes u can make a projector with a single fresnel provided u use an elliptical or parabolic reflector....can u plz share frm where did u buy triplet ? |
#1284 |
will it be possible for you to get me the OHP lens and fresnell sheets .let me try at this one. My email id pricomindia@gmail.com
#1285 | |
I am planning to order the lenses from Optolife.Have you received your order ? How good is the quality? |
#1286 |
#1287 |
#1288 |
#1289 |
Congrats prosenjitnptian !!! job well done
![]() Photos as usual may not do justice to the actual output of the projector, but as what can be seen am sure in real the output of ur projector must be nice bright and crisp. Kindly share all the component details like specs, cost of each parts and most importantly the sources of all the parts procured. This info can be a lot helpful for fellow members in the process of building their projectors. Thanks and do keep posting lots of screenies
#1290 |
thanks nimu for checking my work.
details. split horizontal fold design lcd-b101ew05 1280x800 10.1 inch alongwith hdmi 7 in 1 controller-from Mr hertzblaster sir---diy pj from phillipines fame-------------7000 inr 140/330 fresnel+345 triplet+FS mirror----------from same---4000 inr reflector+condenser---from same(not used in present set up as with big bulb its difficult to use)--------------------------------------------1500 inr smps from e bay india--as lcd and fan power supply-----------700 inr osram hqi-t 250w+phillips 250 w IBU ballast+base------------1900 inr kolkata electrical wholesale market plywood+nut bolt+screw+L bracket+plugs+wires+spike guerd- 1000 inr local shops tempered glass----------------------------------------------100 inr---same electrical market hot mirror------------hind high vaccuam bangalore-----------2000 inr(with shipping and all) 12 volt fans-----------------chandni chowk kolkata-----------50 inr each table for placement of pj-------------------------------------800 inr--local hertzblaster supplied materials qulity wise the best..also enoroumus after sales support by knowledge share.:--) I highly reccomend to go with him.he is a very nice person and can supply you the best diy pj parts at best prices.also one stop shop for all parts taken some proffessional help in ply cutting...:--) as said by someone in this forum.... building was easy....material procurement was the most difficult task...very true. |
