#1251 | |
Even a slight deviation from the center line of the fresnel will dramatically decrease the brightness. |
#1252 |
Hi friends, I have a doubt on usefulness of a reflector. Many of us are using a reflector to maximise the light out put and a fresnel to make the light parellel. The fresnel requires a point light source and we are placing the light at the focal point of the fresnel.
On the other hand a reflector is used to maximise the light by reflecting the light back. If the light source is placed at the focal point of the reflector it also make the light a beam which falls on the fresnel over an area, not as a pointed light source. Then how the fresnel accomodate the light from the reflector?. Or am I missing some thing ? |
#1253 |
hi shivela
can you send some monitor photos. especially the small pcb part which is attached to the LCD. |
#1254 |
HEI good 2007 were is ur exact location am also frm kerala
give me ur ph no am also searching for a good quality lcd monitor |
#1255 |
I am from Cochin. Infact all the monitors 15 inch or above size are good. But some may have the cable issue. Due to the distance problem I am looking for smaller LCDs. ( ideally 10 inch ).
#1256 |
ya mee too ,yesterday i googled for 7" lcd monitor in thrissur local market
but they told they dont have a monitor such as hd quality only they have chepst one around 2500k . can we make the pj together ? Last edited by akhilkumarcs92; 16th February 2012 at 02:23 AM. |
#1257 | |
Do not believe on the resolutions printed on the boxes unless it is of some good brand. Always try to see some video on it. |
#1258 |
Dear Budhi
I am From chandigarh. I got 9.8 Portable DVD with LCD, One 3 mm Magnifier sheet (A4 size). Lamp with reflector and two condenssor lenses containing a fan below the lamp for cooling the lamp. The projection 3let lens i don't know about its focal length. I got all these things from a slide Projector. Can i make it with one Magnifying sheet ??? what distance shall i keep to get an image. I tried it in the moser bare DVD spindle box (which contains 6 spindles of 100 dvds). but the image shows in round on the wall. Thanks in advance. |
#1259 |
lovekesh
i think you are using wrong side of fresnel lens. grooved side should be in the LCD side. |
#1260 |
Thanks Keimjay
but one thing can i make projector with one Fresnel Lens? Is it good to protect LCD ??? |
| Page generated in 0.10151 seconds (76.52% PHP - 23.48% MySQL) with 11 queries |
