Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 17th December 2002, 01:46 AM   #1
Send a message via AIM to verbose mustafa
Default Verbose Mustafa Project Update
Well, over the weekend i did some testing with the parts express 5" lcd screen, and a delta IV projector lens. I think the part of this project I agonized over the most, was the lighting. I finally desided to buy two 12" 6 thousand something lumin flourux lights. Well, just for yux i strapped my lcd screen the my delta Iv without taking it apart. I was treated to a nice 5-6 foot image on the wall (from the tiny little backlight on that lcd). There was one problem of course, it the picture was inverted and upside down. Fixing the upside down was easy... all i had to do was flip the lens the right way (keep in mind i tape the lcd right on to the back of the delta IV). For the inverted problem, i solved that too. If any one has opened up the parts express screen, they would know that the lcd intself can easily be flipped and the unit be reclosed. This is exactally what i did. It worked like a charm. I had a nice big image on my wall, and it was not inverted or upside down. I did not have to use a huge backlight, so really, the projector is only the size of the lens. Not too shabby if i don't say so myself. So I sparred the burden of having a huge, hot, light source, and a bulky box. I can fit the entire unit into a small enclosure. What is the downside, the picture is kind of dim, but a little brighter than the fresnel lens-Big screen tv. This i plan to solve by making the blacklight brighter. I know this can be done and if i succed, i will have one of the smallest DIY projectors out there. My lcd is dead because it was defective (an no i did not connect it to to high power)... the transformer for the backlight shorted out... lit on fire... and now when i power up my lcd... that shorts out... and becuse my powersource lowers the voltage to zero when any thing connected to it shorts out i cannot run the lcd (i would have killed to take some pics first to show. it really was a wonderfull picture!)... Oh well. I'm drawing up the plans for version 2... it will basically be a lcd directly on a projection lens. Trust me on this one... Any ideas?
Old 17th December 2002, 04:59 AM   #2
uvodee's Avatar
Default fluorex
Stafke,
do not say that !!! diy here in this forum do not like the flyorex result!
for some of them it is too easy!
i think it works good, i think it is the easiest and best solution
i used 2 lights and made 3 projectors like that that were sold before they were even finished.
i hope you are prepared in getting negative replies from al lthe others now!
Old 17th December 2002, 08:06 PM   #3
Send a message via AIM to erroljanusz
Default Exact lighting....
HI Mustafa, I was directed here to ask you a question. I did the exact same thing as you, and thats how I plan on doing the final product. I have 5 inch LCD and the DELTA lens. I have a box that will fit everything. I'm just wondeing what kind of lighting I need to produce a bright enough picture. I'm kinda stuck on what to do. I need some help or direction, can you or anyone throw me a tip. I really don't need theories I just want to know the best, then brand name and model number, possibly where to get it too. (as long as the best isnt too expensive.) Thanks!
-Errol Janusz
erroljanusz@aol.com
Old 17th December 2002, 10:58 PM   #4
Hi. Did you try simply plopping your lcd onto your lens with the backlight that comes with it? You may be supprised with the picture brightness, and with a high gain screen... who knows... It may be bright enough... Anyway, the lights i have, i got from the home depot, they are 6825 lumins each fluorex from lights of america. Iwas going to scan the box for you, but my scanner software it dead, so i will post it once i do a reboot. They are $30 each (you may just get away with using one... it depends i how you want you picture to look). Also, these are the coolest running lights to use, but they still produce heat, so make sure you have a fan in your box. And to avoid light loss, put a black piece of poster board, or something over the fan (im sure you could have figured that one out). Good Luck...
verbose
Old 17th December 2002, 11:04 PM   #5
Default Re: fluorex
Originally posted by uvodee
Stafke,
Yea, i know what you mean... I don't see where these people are comming from saying it's too easy???!!!???!!! Most people here just plop an nview on an ohp and then they call themselves DIYers... I guess every businesss person who ever gave a presentation to there company before the all in one projectors was a DIYer to... after all, you do have to take the lcd pannel out of the suitcase, and place in on the ohp. Anyway... im just kidding... the people here are great and so is fluorex!
Old 17th December 2002, 11:15 PM   #6
Default THANKS!
Wow, Thanks for you help. I think I just have about one more question maybe you could help me with. How would I go about positioning the lights. I mean I have the LCD right agaisnt the lens, in a box that is exactly 14 and half inches by 14 and a half inches. Would I angle both lights RIGHT behind LCd or give it a few inches? Do I need a box that big? I had to make a cone out of aluminum foil around a 1750 lumes bulb to fit the exact size of lens/LCD. I shouldn't have to do it again should I? So, in total you recommend at least 12,000 lumes then? I got a few thousand more to go, hehehe. I will take your word and buy those lights tomarrow then. Thanks.
-Errol Janusz
erroljanusz@aol.com
Old 17th December 2002, 11:20 PM   #7
Default Oh, one more thing....
Sorry, I just thought of one more thing. I have seriously like 5 fans and I plan to implement as many as I can. Do you recommend facing them in, and then having one or two facing out for an exhaust sort of thing? Let me know, thanks!
-Errol Janusz
erroljanusz@aol.com
Old 17th December 2002, 11:47 PM   #8
Those lights are very, very bright. They are made to cover 2,580 square feet! I fired up two in my projector box, a wow!!! I was blinded fof a while. As for the angle, you should play around with it. I placed them in the box at an angle like this
shield
___
light 2 \ /light 1
I took the plastic shield off both, and placed one in the front of them when they were at an angle. know on my projected image i did have hot spots, but i am positive i made my box to small, and placed the lighs too close or to far (one of the two) from the lcd. If you have this problem, just put a fresnel lens in there. As for 5 fans, i would lay back a bit, The two fluorex lights are not nearly that hot.. i would say to fans topps, but don't take my word on it. Watch a full movie with likt 1 fan, and keet a thermometer stuck in your box. If the temp reaches over say, 120 F, put in a secon fan to blow air in, or out depending. What kind of lights are you using now?
Old 17th December 2002, 11:59 PM   #9
wow... ignore my diagram... it got messed up... I set them up like zark did... Oh yea, these lights will require some wiring. If you go the the elctrical section of hd (i think the lights were in that section too, and not lighting) you can buy a pigtale (premade plug) and a light switch and junction box ( i belive it is called) and make a nice little setup. You may also want to buy shrink tubing or the little twist things to cover up the exposed wire... you get two with each light though. And one more thing, there is a sensor on the light, that will prevent the light from working in the box... The light will go off. I think it is an auto off for when the light is on duing the day. You can a: remove this sensor, or b: put a peice of paper and tape over it.
Old 18th December 2002, 12:57 AM   #10
nice one, verbose. good work. When you tried the LCD's own backlight with the delta lens did you manage to see a projection of the whole 5" lcd image, or were the corners cut off?
Page generated in 0.12414 seconds (81.21% PHP - 18.79% MySQL) with 11 queries
