Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 26th December 2002, 01:30 AM   #82
Originally posted by Rolm
In any event, I've trashed my OHP at this point (I broke the thermal glass that is bonded to the fresnel), so I'm in the market for another OHP. I will try to buy one that uses an EHJ bulb. If, as I hope, that means that it comes with this apparatus, I will try to do the same mod you have done.
rolm, i have an elmo HP-A305LV (low intensity version of the solar deluxe, has triplet optics) - 24v/250w EHJ assembly with separate reflector, lamp, and lens.
HTH
Old 26th December 2002, 02:53 AM   #83
rusty42 -
If you're interested in selling it, drop me a line at rolm@cox.net.
http://members.cox.net/rolm/results.html
Old 26th December 2002, 08:58 PM   #84
rusty42 -
heh, not really interested in selling it, as i plan to do a similar mod. but check with inventory solutions, i picked it up there for $45. (you may have to call, as i didn't see any on their website)
Old 26th December 2002, 10:51 PM   #85
NP.
Actually, I've been doing some research into which OHPs have this setup (I'm unsure if this is indeed what "triplet optics" mean). It appears that most that use EHJ, EVD, EYB, and FCS bulbs use the same basic layout, but some of them appear to be missing the condenser lens, which doesn't make sense to me.
The real problem with figuring out which OHPs are candidates for this is that you need to see a parts diagram to know if all the components are there.
I also need to do some more research as to what the least expensive approach to bulbs and ballasts. Optimally (for me) would be a 400w HQI or HMI that can use an M59 ballast (that I already have), but I'm not finding it.
Old 27th December 2002, 12:32 AM   #86
remp is offline remp  New Zealand
Account Disabled
Rolm
Far as I know triplet refers to how many lens are in the projection head assy. One , two or three.
Two and three are better than one....so they say
My 3m 1705 has a single projection lens and its spot on.
Old 27th December 2002, 01:20 AM   #87
Originally posted by remp
Rolm
the triplet head assembly is convenient - mine has a rotating lens that focuses, no need to move the entire assembly up and down on the arm.
rolm, check http://www.mbelectronics.com/3M/index.html some of these PDFs have diagrams of 3M OHP internals.
Old 29th December 2002, 04:33 PM   #88
Default Reflector & Light
This a post directed to Rajkumar from another thread "Not Enough Light". I am using an elliptical aluminum reflector from a high bay light like you would see in a Home Depot (a little big though). I have switched from the 400W Philips Metal Halide because they have a "dimple" in the top of the bulb which interfears with the light (this also might be because my condensor lens is not right on the F2). I am now using a 400W Sylvania Metal Halide with better results. If I have time today I am going to be confirming my F1 and F2 positions to be sure I am getting the maximum light potenial from this light.
"Common Sense is the least common sense of them all."
Mains hum on a guitar effect unit! Help (circuit enclosed) HankMcSpank Solid State 10 18th March 2009 12:44 PM
unknown peerless enclosed mid Mark25 Multi-Way 5 11th June 2004 07:35 PM
would it be okay if I spray paint an enclosed transformer? jarthel Everything Else 1 21st June 2003 05:19 PM
outboard xover - enclosed or not? jmpsmash Multi-Way 23 24th October 2002 01:26 AM
Page generated in 0.10455 seconds (78.62% PHP - 21.38% MySQL) with 11 queries
