Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 10th February 2006, 08:28 PM   #1
Re-Animator's Avatar
Send a message via MSN to Re-Animator
Default Retrofit a InFocus lp 580
I have got this projector for the sole purpose of putting in a cheap bulb, also it does not have the origenal lamp, so here is my idea/question wat kind of lamp do i need to put in hti,hqi,cdm-t etc.... that will work with the internal ballast. I know it runs a 150 watt MetalHalide bulb at 65 volts. Also where would i get it from how could i build a reflector?
ps im a lost sheep
but i am optimistic
pss i have found that other thread
Old 10th February 2006, 09:44 PM   #2
are any of these suitable?
http://www.steinigke.de/shopneu2/?id...57978e84de6fe0
Old 11th February 2006, 02:44 PM   #3
Could i use this as a reflector and put a metal halide bulb init, like a cdm-t etc..?
File Type: zip could i use this reflector with a metal halide bulb.zip (90.0 KB, 38 views)
Old 11th February 2006, 11:11 PM   #4
no one gonna help, plz help me
Old 12th February 2006, 01:40 AM   #5
ywh is offline ywh
Send a message via MSN to ywh
which one is your like?
Old 12th February 2006, 11:00 AM   #6
I have'nt got a lamp module so i dont't know
Old 12th February 2006, 04:07 PM   #7
Well i did and i think it is 3 inches squared, also i took some photos of inside the lamp compartment.
Old 12th February 2006, 05:22 PM   #8
"Diy" Metal halide in commercial projector
That is the older thread bout the same thing
Old 12th February 2006, 05:45 PM   #9
my1423 is offline my1423  United States
1. Look up the original replacement part number from the manufacturer.
2. Do an internet search for the bulb. Most supliers will post pictures and specs.
3. After this you can maybe go to a local repair shop and find a burnt up version for free or at least what it looks like in person.
4. Post what you found and maybe someone can help you.
5. I personally was trying to find a replacement for an osram vipr273/35r for my davis power beam 6. I tried a higher voltage bulb and the electronic ballest would not keep it going. If you are going to use the original ballast you must find a bulb of the correct or lesser voltage. Im sure there is a range in witch the wrong specs will work but im sure it will be close to the original. Too low and you will overdrive it and it will burn up early. Too high and it may not start or may start then shut off early from too high current draw just like my old bulb did.
Old 12th February 2006, 06:15 PM   #10
that is what it looks like, it uses 65 volts as well
looking to retrofit some old JBL's markr89 Multi-Way 2 17th December 2007 08:20 PM
Page generated in 0.07884 seconds (85.88% PHP - 14.12% MySQL) with 11 queries
