Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 8th February 2006, 12:57 PM   #11
Stocker is offline Stocker  United States
how about trying to project with a test image... a thin sheet of paper or something with known-uniform blackness all across?
Jesus loves you.
Old 8th February 2006, 07:15 PM   #12
After considering optics to be an issue i took note that when a white screen is displayed the brightness is very uniform and does not reveal any hot spotting.
Is it at all poisible that the pixles them selfs could have faded some how?
If it isnt that then the only other logical answer would be faulty circuitry....... although like stated before if it was circuitry id expect a specific sharp chang at one point? am i wrong in assuming this
*solid colors generly look uniform across the screen..... tints of solid colors ... ex dark red pronounce the defect
Old 8th February 2006, 10:51 PM   #13
Maybe your reds have started to go. Did you ever overheat that side of the panel? Are all the grounds hooked up like they used to be when it was a regular display? Maybe a too-distant ground could be the problem or noise in the red line????
Jesus loves you.
Old 8th February 2006, 11:01 PM   #14
I havent even considered ground issues
ill try and check that out....
although its ont only the red, dark blue ... gray dark green all do the same....
but I have red improper grounding has caused some issues
MDF edges and screws rinx Multi-Way 32 16th August 2008 03:36 PM
Veneering rounded edges tktran303 Multi-Way 1 27th June 2007 01:54 PM
Page generated in 0.07945 seconds (70.74% PHP - 29.26% MySQL) with 11 queries
