Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 26th January 2006, 10:11 PM   #1
scanboy is offline scanboy  Hong Kong
Send a message via AIM to scanboy
Default Need help with EMF(???) interference
I have just finish building my projector (been waiting for this moment), but when I flip the switch on, I can't get a clear picture from the LCD
After taking the LCD out of the box, the picture starts showing again, I then realized it might be the ballast that is interfering it.
Does anyone has this kinda experenience? I wonder what I can do without modifying the box too much. I am using LL's lamp with their electronic ballast. I've left out a lot of details in the bmp, but this is how it is setup: light goes from left to right (obviously), and the lamp has its own enclosure, with the PCB of LCD sitting under it, all the wires goes between the LCD and PCB. The ballast is mounted vertically isolated from the lamp (with wood), but not from the LCD.
Is it the LCD, the wires between LCD and PCB or the PCB board that is being interfered?
Delay no more
Old 26th January 2006, 10:22 PM   #2
is it simply plugged into the same outlet? maybe avoid that and it will stop?
man, i hope i don't run into this problem myself when i construct mine.
Old 26th January 2006, 10:38 PM   #3
I have a power strip inside the box with a single power wire going out to the wall outlet. I am not sure if this is the cause, but you just gave me another idea to try.
Delay no more
Old 27th January 2006, 04:24 AM   #4
Send a message via AIM to politicorific
Absolutely what your describing is interference. My 2nd LCD had this problem - bare wires instead of grounded cable. Course I didn't realize it until I broke my LCD thinking it was the ffc.
Try building a metal shield around the ballast and ballast wires. Couple bucks of material and you should be fine, although heat may be an issue.
Old 27th January 2006, 05:51 PM   #5
Thanks, I will pick up some sheet metal from HD and cover them up. I hope this will solve the problem.
Delay no more
GSM interference watermelonman Tubes / Valves 9 25th October 2008 07:01 PM
Really bad interference... how to fix? dxg Everything Else 11 14th November 2005 01:48 PM
FM interference with AR sub mashaffer Subwoofers 0 21st July 2005 12:31 PM
Interference Prune Everything Else 1 22nd September 2003 04:37 PM
DAC interference problems MWP Digital Source 8 16th September 2003 05:15 PM
Page generated in 0.07456 seconds (75.13% PHP - 24.87% MySQL) with 11 queries
