#41 |
Would the stock fresnel lens set in a 3M OHP be enough for a 400 Watt light setup? What about the 250?
ps - This is what part of the alphabet would look like if Q and R were eliminated. |
#42 |
Ok, so it looks like if i use the 250W MH light set the base will be approx 10.5 inches from the light source. Does that sound about right? I put a reflector behind the MH bulb and then set my OHP fresnel lens and glass centered right above that. Should any of that be a problem? Will the light be too bright for the stock 3M fresnel lenses?
| Buying sharp, Nveiw, proxima... Projection panel | robmooz3 | Swap Meet | 0 | 18th August 2004 01:21 AM |
| Page generated in 0.05954 seconds (67.92% PHP - 32.08% MySQL) with 10 queries |
