Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 2nd February 2006, 06:06 AM   #11
Send a message via AIM to politicorific
dump the IR glass for larger setups. I've been running my projector without it from the beginning and my brains haven't melted yet. Just make sure your fresnel setup is cool, they will warp and cause problem s if not taken care of. IR is necessary on smaller 7 inch setups because airflow is less. On larger setups a couple fans should be able to move enough air to keep things cool
Old 2nd February 2006, 01:32 PM   #12
newby is offline newby  Canada
Thanks for all your help.
Old 6th February 2006, 11:11 PM   #13
rob1231 is offline rob1231  Canada
Send a message via MSN to rob1231
Default whoa newby..you live in Ottawa..crazy
I just saw that you live in Ottawa Newby..crazy. I live just over in Almonte. Where did you get your lens and how much did it cost?..find any stores in Ottawa that sell stuff like that. Im making a ps1 projector and im trying to persuade my dad to buy it over the net (80mm Triplet) but I was wondering if you saw any in Ottawa.
Thanks Rob
Rob Smith
Old 7th February 2006, 12:48 PM   #14
Hi Rob,
I bought my lens from DIYProjectorCompany. It's the 135mm long throw lens because I'm using a 15" LCD and I wanted the projector to be far enough from the wall. It's $120 US. The only thing I could find so far in Ottawa was a 400watt MH light at Home Depot but no ballist and the Lexon also from Home Depot. If any one knows where I can find a mogul base and ballist in Ottawa I'd sure like to know because DYIProjectorCompany is having problems getting the 250W light I ordered 01/11/06 and as others told me, I'd be better with the 400watt. I know Alan is trying but man, I'm getting anxious. I think the price there is excellent for the 80mm lens and that should be good for you.
Old 7th February 2006, 03:45 PM   #15
hey man
Just use one of these things...
URL=http://img.epinions.com/images/opti/2d/3e/Regent_Lighting_500_Watt_Deluxe_Work_Light_PQ500WL _Shop_Tools-resized200.jpg]Work Light[/URL]
thats what i have in mine, It gives out good ligh, but is quite hot! at $15 at the canadian tire in carlton place, its a steal!
Rob Smith
Old 7th February 2006, 03:47 PM   #16
dammit here is the url again
Work Light
Rob Smith
Old 7th February 2006, 04:45 PM   #17
Thanks Rob. I have a 500 Watt one from Canadian Tire but it gets way to hot.
Old 7th February 2006, 05:25 PM   #18
Like people are syaing I think with 250W you'll need a good reflector to get a viewable image in the dark.
Currently with no reflector and a 400W lamp my image isn't that bright, although perfectly viewable in low light levels.
I haven't used IR glass, just some UV reflective polycarbonate which attenuates anything below 390nm.
Its been running for 100 hours now with no overheating problems or yellowing.
www.diycinema.co.uk >> loads of info on NEC panels
Old 7th February 2006, 06:34 PM   #19
Thanks for the info goodbyeqti.
I hope the reflector will do the job.
Page generated in 0.08896 seconds (76.34% PHP - 23.66% MySQL) with 9 queries
