Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 11th January 2006, 03:02 PM   #1
hshah is offline hshah  United Kingdom
Question bulb and lumens
i can get hold of projects for a cheap price but for only 2000lumens. can i increase the ammount of lumens on that projector by changing the bulb or do i need to look for another projector with 4000lumens??
Old 12th January 2006, 02:54 PM   #2
anyone?? any help please?
Old 12th January 2006, 03:25 PM   #3
v1d9uy is offline v1d9uy  United States
most of the time no .. other bulbs wont worth with other projectors now you could RETRO fit them by mounting a metal halide setup in side of it ....but after all that work .. you may as well just build your own box
Old 12th January 2006, 04:32 PM   #4
how do you fit in a metal halide setup? what do you need to do to fit it in a OHP?
Old 12th January 2006, 05:29 PM   #5
http://www.allinbox.com/retrotft/retrotft.htm
that is a OHP that was retro fit with a HQI metal halide setup ... you just have to gut the OHP and setup the MH inside ..... its not that hard but you will have alot of light leaks .. unless you do sorta what he did there with the plywood ... but after all that you could just build a box ...
witch means you really dont even need the OHP .. unless you wanna try and use the fresnel and projection lens
Old 12th January 2006, 06:31 PM   #6
so i have decided to get an OHP but will replace all the lighing to a metal halde bulb. i am intrested in this bulb:
http://cgi.ebay.co.uk/400W-METAL-HAL...QQcmdZViewItem
what other componets do i need to connect the bulb?? i.e. ballasts or anything special. i want to make a whole new circuit for this new light setup inside the OHP. what other components do i need??
Old 12th January 2006, 06:48 PM   #7
BALLAST = http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
BULB
http://www.atlantalightbulbs.com/eca...HI-S400DDUSHIO
thats what i will be useing cheap ballast good bulb
when looking for a bulb yer gunna want long life , good color temp around 5000K , decent price and its gatta be bright the bulb there has 33,000 lumens.... now only around* 10% of that light will actually get to the screen ... so brighter is always better
Old 12th January 2006, 09:26 PM   #8
ballast: http://cgi.ebay.co.uk/400Watt-Hydrop...ayphotohosting
bulb: http://cgi.ebay.co.uk/NEW-400w-Metal...QQcmdZViewItem
will this give out a good output? will it work?
Old 12th January 2006, 09:49 PM   #9
well growlights dont have the right color temperture for a projector so you can rule those out as for the ballast im not sure ..... but i know one thing and that is i dont like buying that kind of thing used but thats just me
Old 13th January 2006, 10:07 AM   #10
weel the ballst is new, thats what i have been told by the seller. i am still looking for a decent 4000W halide bulb. if anyone can find a good one on ebay.co.uk i would appreciate your help.
Page generated in 0.09480 seconds (80.37% PHP - 19.63% MySQL) with 10 queries
