Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 8th January 2006, 06:15 PM   #1
Default uv/ir placement ?
ok im doing the sv11 design dpc has and im just wondering i need to put glass/fresnal/fresnal/glass iv seen maney threads on it but i would like others input sence i keep seeing dif. answers on them.
ok my ? is do i do.....
back to front
(A). UV glass/fresnal/fresnal/IR glass
or
(B). IR glass/fresnal/fresnal/UV glass
and why that way?
thank you
Old 8th January 2006, 07:31 PM   #2
v1d9uy is offline v1d9uy  United States
ok i dont get it ... if the uv/ir glass is supposed to protect the lcd .... shouldnt they both be between the bulb and the lcd ?
bulb--uv/ir--fresnel-lcd-fresnel-projeciton lens ? remember the more stuff inbetween the bulb and the lens the darker the picture
10% light decreass per sheet of glass ! or something like that ...
Old 8th January 2006, 09:18 PM   #3
yes it is from light to lcd thats what i ment by back-front
Old 8th January 2006, 09:55 PM   #4
(A). UV/IR glass / fresnal / LCD / fresnal / lens
( if for a split fresnel design)
or
(b). UV/IRglass / fresnel / lcd / lens
non split single fresnel design
Old 8th January 2006, 09:59 PM   #5
not on the sv-11 it goes glass/fresnal/fresnal/glass
http://www.diyprojectorcompany.com/d...v11/sv11_3.htm
Old 9th January 2006, 11:17 AM   #6
Guy Grotke's Avatar
Default IR then UV then fresnels
IR filter near the lamp to keep most of the heat out of the rest of the box. (Also keeps your UV filter from melting!)
Then the UV filter to protect your fresnels and LCD from UV damage. (Lexan XL10 from Home Depot is fine.)
Then fresnel/fresnel/LCD, or fresnel/LCD/fresnel.
You can use the Lexan right up against the first fresnel to support it, if you like.
Most of the light from the lamp and reflector should either go through the IR filter or hit an aluminum shield around the lamp. Lots of designs use an aluminum box around the lamp with a hole for the IR filter, and both long ends open for air flow. Fan goes on one end to pull air around the lamp and dump it outside the box. Very cool-running design.
L pad placement.... Big_Bill Multi-Way 6 22nd July 2009 03:21 PM
Placement lpd Planars & Exotics 0 20th August 2008 11:39 PM
Opt placement Niila Tubes / Valves 1 20th March 2008 07:04 PM
sub placement chainenoble Subwoofers 3 13th October 2006 03:45 AM
Placement of PR on a sub box Stantob Subwoofers 5 16th January 2006 10:21 PM
Page generated in 0.08826 seconds (72.60% PHP - 27.40% MySQL) with 10 queries
