Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 8th January 2006, 02:20 AM   #1
Default SnortonNorton's build, day one.
ok, got everything i need. Got the 28 dollar HPS ballast, the ushio lamp, got it wired up for testing, man that baby is bright.
got the MDF, got the DIY friendly 15 inch lcd, got some fresnel, got some 327mm lense, got the lexan XL10 to protect them. got the fire extinguisher (seriously) got this work station pretty much loaded up not to mention the tons of tools under my student housing apartment bed....... ( i own a antique british bike so having tools is absolutely necessar)
first of all, since i want to do this right the first time, i want to measure everything a million times than design the enclosure around it all.
now for FAN cooling, check this lasko thing out from Wallymart. my buddy used it to cool his 500 dollar graphics card while we're toasting suckers on Battle Field 2. then he got a water cooling kit and he gave this to me. It's a squirrel cage design, and very very quiet, it's about as load as a PC power supply. how can i incorporate it to my enclosure?
use pvc that is same size as the squirrel cage parts and suck in the outside air, then point the blower onto the fresnels/lcd's?
Old 8th January 2006, 02:22 AM   #2
took off the stupid safety crap, then i can use pvc that shoots out to the enclosure's walls, and suck in air............
****, just realized that means i'm gonna have to cut more circles with the jig saw, i suck at that. i use to be a machinist apprentice and could make stuff out of metal, but i suck with wood work..
any suggestions on cutting circles with a 20 dollar jig saw?
Old 8th January 2006, 02:24 AM   #3
here is the work station, i saved some pc fans but won't neeed them if i use the big fan right. (don't want to use a power supply.)
Old 8th January 2006, 02:58 AM   #4
got the fresnel back out, gonna use the one piece (two stuck together, seemed to work fine on the ohp)
look at that beautiful mirror (in the ohp body, not the mirror for lense top), maybe i'll put that behind the ushio lamp, ( not gonna buy the quiche mold now, i think 25 dollars to ship from canada for 12cm item is criminal.)
also got the 327 mm lense off of the armature, WHY DOES THE INPUT SIDE OF THE LENSE HAVE A SEPERATE GLASS PIECE IN FRONT OF IT ? SHOULD I KEEP IT?
Old 8th January 2006, 02:59 AM   #5
the out put side of lense.
Old 8th January 2006, 03:00 AM   #6
the carcass.
it was a Dukane Starfire 4003, high quality so i think the 327 lense will suffice, it was actually made to handle lcd panels.
Old 8th January 2006, 03:47 AM   #7
damn, i just realized if i use the squirrel fan sucking in cool air and blowing in the fresnels and stuff, i'll steel need a small fan to suck out the old air from enclosure.
man, the pc power supplies are so big, any other way to power a small computer fan?
Old 8th January 2006, 07:54 AM   #8
Use a DC converter wall plug.(like for a cordless phone or something) Check rating on plug though. Looking good! Keep Updating.
-Bit
Old 9th January 2006, 04:06 AM   #9
ok, till i figure out how to either fix the ffc problem, or sell this one on ebay and get another, i can't update till next week or so. but i promise a good follow up on the enclosure once i have the lcd working right.
Old 9th January 2006, 06:03 AM   #10
Stocker is offline Stocker  United States
Why do you need a fan to suck and a fan to blow? It seems to me that the most you would need is to put some strategically placed exhaust holes where needed for optimal airflow across what you want to keep cooled off. The air will take care of itself getting out!
Jesus loves you.
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
build or buy navin Multi-Way 9 16th November 2004 04:36 AM
Looking to build a sub. jaybird Multi-Way 6 14th May 2003 12:52 AM
Page generated in 0.10004 seconds (79.37% PHP - 20.63% MySQL) with 11 queries
