#11 |
Having an in/out fan arrangement creates a more laminar flow of air. If you just have air holes for an output, your air flow will be very turbulent, and some air will circulate around inside the box longer than you want. The longer air circulates around a heat source, the hotter it gets. It may only cool the box a few extra degrees over a hole arrangement, but cooler is always better.
#12 |
I believe stocker was talking about air holes as input, so you just need one fan to suck out the hot air. If your holes placement were correct, the air flow will cool whatever that you wanted to cool. If fact, if you have a higher flow fan blowing air insdie and a lower flow fan blowing air out, this will also create air turbulance inside.
Delay no more |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| build or buy | navin | Multi-Way | 9 | 16th November 2004 04:36 AM |
| Looking to build a sub. | jaybird | Multi-Way | 6 | 14th May 2003 12:52 AM |
| Page generated in 0.06421 seconds (67.47% PHP - 32.53% MySQL) with 11 queries |
