#11 | |
![]() I had a considerable annoyance because of the clamp on the lcd circuit I'm trying to move out of the way broke, so I had to use a document clamp ( taped to make it non-conductive ) to hold the extension in place... still it worked out, phew. But now I have to tackle a problem I am having with the picture, it seems there are small horizontal lines passing on the screen... (minor but annoying ) could it be related to the PC PSU I'm using? mmm... well, tomorrow I'll begin assembling the components in the case, as always, I'll be back with updates! |
#12 |
Glad that your FFC issue seems to be under control. As for the horizontal lines issue I can't say for much since I've never run into this problem. I've been running my LCD off of my active computer's PSU with no problems. The only type of interference problems I did have at one point was that I used a spiral flourescent light bulb to view the screen when I had it stripped apart for the very first time. The motion of the movies I was watching was juttery. I thought I had botched something in the stripping attempt but when I view the screen again but with a incandescent light bulb the problem went away so I'l assuming that the flourescent lamp was giving off radiation that was interfering with the function of the screen (those spiral type bulbs all have a power ballast at the base). Have you tried moving the PSU around and perhaps away from the screen? I think that you may also find other threads that could help you, just use the search.
Peace! Chris B. in Iowa |
#13 | |
...well, I searched the forums for any similar problems (aka moving lines) but I didn't really find anything related. I tried moving the PSU away from the setup but it didn't seem to change things much. so I came to 2 logical deductions: > There were multiple ground wires in the screen, that I did not re-ground once disassembled, maybe they could affect the image? > I'm using a monster of bulb, it's a 500W Halogen @ 8500 lumens, maybe it's causing drastic radiation? ( btw, to prevent the LCD Panel from catching instant fire I'll be using a fire place glass between the light and the lcd... maybe that could stop some of the nuisance? ) Well, tonight is the night I start really testing distances of the fresnel and lens! Peace Chirs |
#14 |
"> There were multiple ground wires in the screen, that I did not re-ground once disassembled, maybe they could affect the image?"
I too have a sneaking suspicion about the grounding of the boards. When I first tested my screen (before stripping) it was functioning fine, I could access the contrast/brightness menu and so on....only thing broken was that the backlights were out. After having the thing apart I can't get to the menu anymore. The only button that function on the control strip is the power on button. This is still workable for me as I can just use my nVidia card's settings to change the contrast/brightness but I kinda irks me to have lost the menu, it feels kinda like a half broken screen. I haven't tried yet to take the time to carefully use jump wires and ground the boards to the back metal frame and see if that works. Did you have the red line problem before you installed the FFC extension? Or did this line problem happen after you stripped the monitor? I've tried looking up some stuff about grounding the screen but can't seem to find anything that's clear and concise. IF ANYONE CAN HELP WITH SUSPECTED GROUNDING ISSUES PLEASE HELP! Good luck! Chris B. in Iowa |
#15 | |
that's sad . It seems that contrast/brightness settings are crucial to get a decent picture... But you say the power button is doing fine? mmm... Indeed, cables to relay the grounding might be the solution. I'm gonna try it in the coming days, it looks like the easiest way of grounding all there is to ground without moving anything, ..., I too have a problem with a certain button on the control panel, the 'exit' one. > Did you have the red line problem before you installed the FFC extension? well, I have the problem since the first time I tested the monitor after stripping, so it's definetly something I've done in the process. let's investigate |
#16 |
Hmm.... you've got a Exit button problem too..... yes let's investigate the theory of proper grounding.
Good luck to you. I may look into this with my monitor over the weekend. Keep us posted, i'll do the same. Cheers! Chris B. in Iowa |
#17 | |
tanx |
#18 |
Are you describing the delicate flat cables that connect the LCD glass to the bottom circuit board? Not the FFC that's been extended right? I wouldn't recomment folding or bending the flat cables too much for I've read about people ruining their LCD from too much handling. Kinda like how a paperclip eventually breaks after being flexed too many times. The spot specific stress of folding a cable may not be good. What I plan to do for mounting my LCD screen in my box is to first use the original metal frame hounsing that came with the LCD it provides a nice "frame" that takes the stress of mounting and supports the LCD, I might use RTV silicone sealant to mate the LCD to the metal "frame".
After breaking my OHP lamp over the weekend I decided that I better not get hasty and break something else. I was testing out my lamp holder to see if it could take the high heat generated from the lamp and it did quite well! The only thing is that I stupidly got my finger caught in the cooling fan when moving it and the sudden shock broke the filament in the bulb. I'm not too bummed about it since I know that the cooling aspect works. Now I'll be into constructing my triplet lens focusing assembly. Just remember to reserve plenty of time when dealing with the LCD, such as your efforts at mounting it in your box. I try to remeber that it's the core heart of any PJ. Without it we've only got a fancy box with a light and a few lenses in it, the best you could do with that is make Japanese shadow puppet theaters. I sometimes like to break out of my own mental box and imagine another method of approaching the problem. This sometimes reveals a different and better method at overcoming the problem. I know I had to do this a few times to get my lamp cooling problem solved. Keep us posted! Chris B. in Iowa |
| Fried T-Amp? | Bingobing | Class D | 11 | 2nd November 2010 02:12 AM |
| Fried t-amp? | kaban | Class D | 24 | 23rd June 2006 09:03 AM |
| Fried New Amp | memito | Car Audio | 8 | 10th August 2004 01:38 AM |
| I think I fried an amp | mashaffer | Car Audio | 1 | 20th July 2004 12:54 AM |
| $5 SE amp... but is it fried?! | SHiFTY | Tubes / Valves | 3 | 18th January 2004 03:13 PM |
| Page generated in 0.13233 seconds (86.72% PHP - 13.28% MySQL) with 10 queries |
