Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 15th December 2009, 02:56 AM   #131
3dlens.com or try a photographic shop
Don't know if you can get for much cheaper, but it should work. just make sure that it's a the correct orientation when placing it over (ie. it can't just be stuck over, you'll have to rotate the film until you can see a picture through it, then secure it down)
Also, you'll want to get the non-adhesive type
Old 15th December 2009, 03:14 AM   #132
Default dumb question...
thanks, good stuff.
i only removed about 2 to 3 inches off the right side of the monitor...
if i get a small piece of polarizer and meticulously place it over the missing parts, will the line be very visible in the end result on the wall?
Old 15th December 2009, 08:06 PM   #133
Not sure. But I think yes - at the end of the day, projection does magnify everything!
Old 25th December 2009, 11:27 PM   #134
The best way I have found to remove the AG is to soak 2 layers of bounty paper towels and lay flat on the lcd. Then cover with DRY towel for about 3 hours..It peels off like a candy wrapper
Old 2nd March 2011, 10:18 PM   #135
i remove it perfectly.
Old 28th May 2011, 05:50 PM   #136
Default Dell 153fpb 15 inch
I just used an old shirt and an old pc case and layed the lcd panel on it and covered it with another shirt then just poured water on it.And left it for 3 hour's then i took and ipod screw driver and poked at one corner. And pull a little up so I just peeled the rest off in easy in one shot.Yeah i know its dangerous but i dont give a dam about this monitor it wont do 1920 x 1200 resolution.But i got a 17 inch that will haa haa thats next.But i still got to get a new bulb to really see if there any real difference since I removed the ag
Old 30th May 2011, 05:38 PM   #137
Yet agian with my 17 inch monitor ive had sucess same methods
50 or 60 hz hum removal from WAV (+) VEC7OR Everything Else 2 11th March 2004 05:39 PM
Page generated in 0.07987 seconds (71.91% PHP - 28.09% MySQL) with 11 queries
