Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 26th November 2005, 11:16 PM   #91
(Edited by moderator at the request of a member. This post now lacks relavance)
So, you are saying that SODA, has altered his image, based off of your examination of pixels when zoomed all the way in??
Just making sure I understand you, Ive looked at the image, and read your description twice, and I cant see what you are getting at.
SODA's picture didnt seem to be soo glorious for it to be fake, I simply cant believe that image has had effects added to it. Doesnt this GIMP program tell you what was done in photoshop ect.
If you examing pics from close up to determine if effects have been done on them, I dont think that is a concrete accurate way of determining so, Many things can very, the Jpeg compression of colors, the compression setting,for example, how would a hi-res image look when saved at high quality setting (12 in photoshop) versus low quality setting (1-3 in photoshop)?
It looks as if you possible raised the brightness or lowered the contrast in your snippet, hard to say. I can see the difference between the two pics, but unless you have two pics to compare, I Just simply cant see how you can look at ONE image and determine an effect was applied to the image
Old 27th November 2005, 07:58 AM   #92
gabel87 is offline gabel87  United States
OK, back to a/g removal. after an easy removal of the viewing side antiglare on the proview 15.4, I tried the a/g on the back side with the wet rag method. It wouldn't budge. even after 24+ hrs, it wasn't coming off. so I gave up on that side for the moment. yesterday, I got the pj back together and tested it. it was only slightly brighter and clearer. still not what I was hoping for. then I went and looked at a sharp QA-1200 I have laying around that a friend left for me to mess around with. holding up the sharp projection panel you can clearly see through the panel. unlike our stripped lcds. at this I decided that I simply must remove the rear a/g or get another lcd. since the rag method was not working on this side, go figure, I used the paint stripper method. This method scared the hell out of me but I was determined to remove the rear antiglare. Even prepared for the possibility of accidentally messing up or removing the rear polarizer. long story short, I got the a/g off but the polarizer got damaged to some extent in the process. diagonal lines were opened up by the stripper leaving small diagonal scrath-looking marks on the polarizer. But fortunately the panel still works fine and the marks aren't as noticable in the projected image as I feared they may be.
After removal of both front and rear a/g layers I can now clearly see through the panel just like the QA-1200 panel. like a tinted piece of glass, glossy on both sides. I reassembled the pj and was impressed with the results. It is now definately brighter. without any kind of reflector in the projector I projected a completely watchable 9' diag. image on a darkish green wall and tan miniblinds through the middle. I am very happy now about the future of this pj. the color was good, and the clarity definately also improved.
I would not recommend anyone use the stripper method on this panel. it will damage the polarizer. I am just lucky it isn't bad enough to ruin the image. I still will probably look into replacing the rear polarizer at some point. part of my problem may have been that the panel was framed and I couldn't get the razor flat with the panel to get under the a/g on the rear with the rag method. the front came right off though, almost too easy. I can't believe the rear was a totally different experience...
Added:
One more interesting note about this was that after the a/g removal of BOTH front and back the heat(no cooling in pj yet) was no longer causing the screen to black out like before. It still did it w/ only the front a/g off. but with both off it would run for 30 minutes before showing signs of darkening. So either it is allowing the panel to passively shed heat better or there is some other thing at work here.
Old 27th November 2005, 09:56 AM   #93
Dazzzla is offline Dazzzla  Australia
That was one of the proposed benefits of this mod at the start of the experiment at lumen labs. I know of another member who had heat reduction as well, there are probably more but I think it doesn’t get reported that much because of the excitement of image improvement.
Old 28th November 2005, 03:33 AM   #94
SODA is offline SODA  Abu Dhabi
There was no editing done. My projector isn't fully finished and I have to cover top part of lcd with paper otherwise it is exposed to light.
This picture is straight from camera.
- SODA
Old 28th November 2005, 01:09 PM   #95
Default to annul the dispersing effect of the light by antiglare
para anular el efecto dispersante de la luz producido por el antiglare.
pintar con barniz transparente el filtro antiglare,esto produce que el antiglare se vuelva tranparente y la luz no se disperse.
yo no lo he probado ,"voire" en el foro de allinbox esta haciendo pruebas actualmente.
este metodo es minimamente destructivo.
si funciona bien,por favor poner fotos del antes y after.
disfrutarlo.
faltaria determinar que esmalte es mejor,
como pintar
(spray,brush),modo de paint.etc
in order to annul the dispersing effect of the light produced by antiglare. to paint with varnish is transparent the filter antiglare, this produces that antiglare becomes tranparente and the light not to disper itself. I have not proven it, "voire" in the forum of allinbox this testing at the moment. this metodo is minimamente destructive. if it works well, please to put photos of before and after. to enjoy it. faltaria to determine that it enamels is better, like painting (spray, brush), way of paint.etc
pour annuler l'effet dispersant de la lumière produit par l'antiglare. peindre avec vernis transparaît le filtre antiglare, ceci produit que l'antiglare se retourne tranparente et la lumière se pas disper. je ne l'ai pas prouvé, "voire" dans le forum d'allinbox il fait des essais actuellement. cette méthode est minimalement destructive. s'il fonctionne bien, s'il vous plaît mettre des photos de le avant et d'ensuite. jouir de lui. faltaria déterminer qu'émail est mieux, comme peindre (spray, avec pincel), mode de pintar.etc
jejeje
Old 4th December 2005, 07:52 AM   #96
So I got brave this weekend and tried the A/G removal. Here are some pics of the process:
I used plain old paper towels and wet them in the sink until they dripped when I held them in the air. I did cover the towels in plastic wrap to hold in moisture (not shown in pic).
This is what the LCD looks like with no A/G filter; strikingly similar to a "glossy" LCD.
The A/G filter held up in the air. Holding it in the air is a little exaggeration because when it's actually being used it's glued directly to the LCD; not floating 3 feet in front of it.
So I did a little better comparison of A/G vs no A/G. The A/G filter is laid flat on the table. This one is with a flash. You can see the right side (A/G filter side) is more dull, dimmer, and slightly blurred.
This is the same setup with no flash (the light is overhead lighting).
So what do I think? Well, the image is definitely clearer. Sharper, more contrast, a little brighter too. How much more? Well, enough to notice but not night and day. Was it worth it? I think so. It really wasn't hard at all. Soaked it for about 6 hours. Then, used my thumbnail to get an edge started. Peeled right off with no problems. The most difficult part was not breaking the EXTREMELY delicate ribbon cables connecting the LCD to the controller board. That scared me way more than the actually stripping did.
Old 4th December 2005, 05:31 PM   #97
hey to remove any residue from the adhesive i used a bit of regular ol armorall worked awsome
but use at your own risk
Old 23rd December 2005, 08:09 AM   #98
Hello,
I'm taking somewhat of a shot in the dark by posting here, and I apologize because this may be considered off-topic (but it's directly related to removing the AG layer from an LCD panel).
I know nothing about projectors, but I come from a similar school of internet-folk: modders. Over at notebookforums.com, some of us have decided to try and find a solution to our laptop screens looking pretty awful (poor viewing angles, terrible contrast/vibrancy, etc). Lo and behold, I see that you guys do some pretty wild stuff to LCD panels that looks very similar to what we're trying to achieve.
In the particular line of notebooks we're looking into modding (Dell Inspiron 9300) there are only 2 screens. One is 1440x900 with the traditional AG screen, the other is 1900x1200 with the shiny stuff. On a 17" screen, 19x12 is ridiculously small and hard on the eyes. So, we've been trying to figure out a way to improve the 1440x900 screens.
So, here's where I have lots of questions.
1. Did removing the AG layer improve the viewing angle at all (or is that irrelevant with a projector)?
2. I noticed the process involves a lot of water. I know this is probably a stupid question, but does that mean that getting the LCD wet causes no damage as long as the electronic parts stay dry?
3. You guys may not be able to answer this, but after removing the AG layer, would applying an AR (anti-reflective) layer over the newly stripped LCD further improve the visual quality?
4. I can't tell from the pictures - how far is the LCD disassembled before soaking it?
5. I suppose this is an important one - How much damage can be caused by this process, if you're very careful and follow directions (i.e. not tossing it into the bathtub overnight)?
I apologize for the mass of questions, but I was extremely excited when I finally found relevant information. We've been researching this for weeks with no luck (a friend of mine has even been calling various LCD manufacturers around the world looking for more information).
Old 23rd December 2005, 05:41 PM   #99
Jenny, I actually was one of the early posters on notebookforums.com. I am Asdasl on there. I actually own an I9300 with 1920x1200. Yeah, those darn sparklies.
Ok to your questions:
1. It is irrelevent to a projector (light comes out the LCD straight, theoretically). But, I do believe the viewing angle was increased. The purpose of the AG (anti-glare, also known as anti reflective) layer is to reduce the glare you get from ambient light shining down on your screen. In a projector, the light goes through the back of the LCD and through the front. No light (theoretically) goes back through the front. I would say the viewing angle has more to do with the polarizer than the AG layer. Please correct me if I'm wrong.
2. It's just like cleaning your screen. The water isn't oozing all over the place, but it is soaked. As long as you let things dry, you should be all set.
3. AG is the same as anti-reflective
4. The LCD is disassembled so that the actual LCD (AG layer, polarizer, LCDs) are exposed and accessable. This might be tricky with the 9300 because when you just take the LCD out of the bezel, you still have a metal frame to remove.
5. You can destroy the LCD by doing this. The biggest risk is breaking the polarizer. When the screens cost something like $250 each (on the I9300), that could be very costly.
If you remove the AG layer off the 1440x900 screen, you'll probably end up with a "shiny" screen like the 1920x1200. Let us know if you try this and your results. Good luck!
Old 23rd December 2005, 06:11 PM   #100
pepe303 is offline pepe303  Poland
I wouldn't recommend doing this to an expensive laptop screen, for couple of reasons:
- you can damage it during the process, it would be best if you could practice on a similar, dead LCD, to get the feeling how easy/difficult it is, how much force you can apply, and so on
- if there is some glue left after AG removal, it will look bad on you laptop screen (not a big problem with a projector, it's hardly noticeable on the big screen), and I bet you will try to somehow remove those traces, trying some solvents, rubbing, and there is a risk that you will make it look worse, or even damage the polarizer
- assuming you wil succesfully remove the ag, then the underlying polarizer is very fragile, and regular cleaning might be problematic (not a problem in a projector, as you don't touch the screen and it's not exposed to any dirt, except some dust). The screen without antiglare will look very shiny and dark, any scratch will be apparently visible and annoying.
In my opinion, you will not improve viewing angle, I think the opposite is true, that the antiglare is supposed to improve this angle, as it serves as a diffusing screen. Imagine it like putting a piece of matte paper on the flashlight. The flashlight without this paper is very directional, light is focused towards it. But when you cover it with a paper, it will become a diffused light source, and loose its directional feature.
Be careful when reading Lumenlab forum. Some people there make very unrealistic claims about benefits of a/g removal. No one from non-commercial forums has yet confirmed those tremendous benefits. You can expect some noticeable difference, but not as huge by any means, while any mistake might cost you a lot of $$$.
50 or 60 hz hum removal from WAV (+) VEC7OR Everything Else 2 11th March 2004 06:39 PM
Page generated in 0.18163 seconds (87.16% PHP - 12.84% MySQL) with 11 queries
