#21 |
A LOT OF THINGS!!!LOL i would love to buy things from you all day long but the import duty fees will kill me. i just though if you could maybe post more pictures or a guide? thanx buddy!
#22 |
Anybody modded the Litepro 550 the same as i got a cheap one off ebay but its a bit dim though the picture quality seems good. bit worried about cooling though, even though the fans make enough noise!!
#23 |
yes! its a bit dim,so I upgrade that light system.
the original lamp is 3500k, that is too yellow. new lamp is 9000K!! FOLLOW ME :-) upgrade that light system. |
#24 |
Follow me? was there a link there because i can't see it?
#25 |
Sorry i mean which lamp and ballast would you recommend that will take the same sort of cooling as the halogen?
#26 |
#27 |
I really need the VGA pinout for the Epson ELP-3000 projector, (Y Cord, Epson P/N: 201 6049) anyone have any ideas on where I can get that?
#28 |
At Epson you can search for the user manual and some other PDFs files.
Go to global Epson home page and then jump to the Canadian site, if I am not wrong you can search the files there. |
#29 |
#30 |
Probably going off the subject a bit, but I have got an infocus screenplay 4800. It uses a 150W SHP lamp. My first question is what is the difference between SHP and UHP lamp and are the Metal Halide lamps. Secondly, can I do a MH conversion, using a single or double ended 150W HTI lamp and using the existing ballast inside the projector.
I did previously build a PS1 screen 250W HQI projector. Was not upto standard so have gone for the other option now as size and quality is a major factor to me. Any help much appreciated. |
| FS: Canadians, Get your 400w S51 Metal Halide HPS Conversion Bulb for cheap! | fenixviper | Swap Meet | 1 | 14th October 2005 05:33 PM |
| Page generated in 0.12840 seconds (77.90% PHP - 22.10% MySQL) with 11 queries |
