Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 10th November 2005, 06:41 PM   #1
Default Cooling Fan basics ? Wiring ? Help I'm on fire!!!
can anyone answer some basic questions for me please:
Building a psone projector, and have the
sony psone lcd/huge lens/120v 300w slide proj. lamp
but no fan, what type of fan should be used here
also, how might you recommend this all to be wired ??
does the lcd, lamp, and fan get wired together and then plug into a standard US a/c outlet, or is more complicated, please help before my pants catch on fire from the electrical hazard that I am about to create..
Old 10th November 2005, 08:01 PM   #2
AAAAAAAAAAAAHHAAHAHHHAHAHAHAAHHAHAHAHAHAHAHAHAHAHH AHAAAAAAAAAAAAA!!!!!!
Stop trying to make me eject coffee through my nose!!!
Old 10th November 2005, 08:12 PM   #3
Send a message via AIM to escalade182
You can buy a pack of cooling fans in bulk. $8 for 12 fans...
brand is mnss cool and they are very powerful yet strong... You can run then with an old computer power supply ($3) and there isnt anything scary about wiring these....all of the connections snap into eachother.
Old 10th November 2005, 08:33 PM   #4
that sounds easy enough
WHERE can i buy the fan(s) ?
and do i pull the computer power supply from an old cpu ?
any help here would be GREATLY appreciated, please send pics of this process if you have already passed this class ! thank you for your fast reply, the burns are getting more severe by the second...
Old 10th November 2005, 08:34 PM   #5
also
I am trying to keep the size of the diy projector to a MINIMUM
how large is the computer power supply ? is it just a transformer to change the voltage ?
Old 11th November 2005, 12:40 AM   #6
you will find most powersupplies around 5.5" by 5.5" by 3.5"....But I have a couple that produce less power (obviously you wouldnt need 300w to power 3 or 4 fans) but the demensions are 2" by 4" by 5" and produces 120w. You can pick one up on ebay for $15...
As for the connections... slot connections...nothing complicated.
Old 11th November 2005, 12:40 AM   #7
also...power supplies have their own switch so you could turn the PSU on in advance to precool the system....or leave it on afterwards to further cool down.
Old 11th November 2005, 12:40 AM   #8
no soldering required...
Old 11th November 2005, 02:44 AM   #9
oh. the website.... www.masscool.com
Old 11th November 2005, 06:46 AM   #10
THANK YOU your kindness will not go unoticed..
Construction and wiring basics for a newbie… DIYNewbie Multi-Way 4 19th July 2004 01:31 PM
Amp on fire Ford_V6 Solid State 12 2nd April 2003 12:27 PM
Amp on Fire! peter5 Solid State 6 7th January 2002 11:35 AM
Cooling an amp with poor cooling BAM Solid State 8 31st December 2001 04:40 AM
Page generated in 0.09788 seconds (88.99% PHP - 11.01% MySQL) with 11 queries
