Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 19th September 2005, 02:09 PM   #11
Rox is offline Rox
Rox's Avatar
you are absolutelly correct. By now we only know the focals are practically simillar as well as the housing dimensions. I have the awi FOV spec but not the besseller FOV spec.
You are right when you say that there can be any FOV on the lens done (this means that the corrections to the aberrations can be made to any desired angle). Let me tell you that the LASER test on the awi, did give us much wider angle than the stated FOV. (laser test=led test practically=what lens sees).
now a last coment, what size is the led, maybe 15 times each individual pixel? and 45 times each indibidual subpixel?
well, i hope you get as good image as posible, will be checking for results. Good luck.
Old 20th September 2005, 02:21 AM   #12
kewl lens! I love it's LF How much did you pay for the opaque projector? And for the field fresnel, what FL you think you'll be using? Eager to see your results
I paid $90 + $30 S/H. That's a little expensive actually. I've seen some go for $50 or even less. The field fresnel will be either the 550mm or a 600mm (ish). Depends on price, split / unsplit config, and throw. I will definitely post my results as soon as I get my other parts in.
Thread Tools
Karlson "projectors" and HF waveguide tubes freddi Multi-Way 3 9th December 2007 10:47 PM
Page generated in 0.14437199 seconds (67.92% PHP - 32.08% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
