Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 7th January 2003, 07:31 AM   #321
Anyone ever seen this before, i picked it up for 10 bucks off ebay, might be some good, can't find any info on it though. It was listed as a NVIEW NEO Systems MDI2308 Multi-Display Interface
Rekr
Old 7th January 2003, 07:43 AM   #322
remp is offline remp  New Zealand
Account Disabled
Rekr
Bottom left is RGB computer input.
Mid right is TTL LCD out.
Bottom right is keypad. Possibly on screen display.
Top right some other connectors no idea what.
Check chip numbers on google might help what they do.
I would guess its an LCD controller.
Old 7th January 2003, 01:33 PM   #323
zardoz is offline zardoz  Canada
Send a message via ICQ to zardoz
Top right looks like power in for the controller (4 pin) and the 2 pin connector looks to be power for the backlight invertor.
zardoz
Old 7th January 2003, 04:26 PM   #324
Thanks for the info, when it arrives, I will take a closer look at the chip numbers and google it.
Rekr
Old 10th January 2003, 05:55 PM   #325
Dnt32 is offline Dnt32  United States
Send a message via Yahoo to Dnt32
Default here are some panels for
these may interest someone
http://www.invsol-inc.com/store/deta...D=General%20AV
Old 11th January 2003, 02:36 PM   #326
Hi all,
I love coming back to posts after a while of neglect and seeing how well they have progressed. You all seem to be leaving the DIY realm and making professional passing projects too!
In the next few months, after I save up the cash, I'm going to finally build my own entertainment unit (ie. my diy projector-pc setup). Just wondering though, has anyone using this method (laptop panel/controll) posted up their results with pics? And whats the quality like compared to a retail projector?
Any panel-controller combination recomendations? Any better (performance and price wise) routes?
I want a target resolution of around 1024x768 w/ 32-bit colour.
I'll be asking more technical questions as time progresses.
Thanks alot all for providing what you have.
Morien
Old 11th January 2003, 03:15 PM   #327
uvodee's Avatar
Default A/D controller
here is another one from ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2087736398
this seems clearly an lcd controller, specs are found when following the link further down the screen.....
still about 50 pct of the sales price.
J-P
Old 4th February 2003, 11:34 PM   #328
I read through some of this thread, like 10 pages but still didn't figure out if some one had put together a cheap pc to laptop screen converter, and how much did it cost
Old 18th February 2003, 07:02 PM   #329
Cool Two new LCD screens to try out!
I'm waiting for my shipment of 2 new screens to try on my controller. I have a 12 inch LG LVDS screen coming as well as a Hitachi 14.1 LVDS . Finally I'll get to see the differance between a low grade TTL panel and a mid range LVDS.
I'm expecting good things!
zardoz
Stand alone HTPC with a laptop LCD screen.
Old 20th February 2003, 01:32 AM   #330
Default LVDS for cheap
Look in the SBC-675 thread.
I have orderd a few of this Aaeon Boards.
They have a flat panel connector on board.
Nexcom, Aaeon, Jumptec , Advantech.
All the same, expensive industrial boards if you get them "new"
I'm developing with such boards as "basis" for
our company. So , I knew the prices.
Also for the addons.
As i see that i can get a cheap Aaeon fullsize board in the "Pentium Class" boards on Ebay i was so happy that i odered direct a few. (unfortunately a few too much).
Forget to route some wires yourself.
It's a differntial signal transmission which transmitts
Pixel Data from Mhz to Gigabits. (hard stuff)
You cannot wheaponed with a soldering iron only,
do such a stuff without getting EMV EMI problems in your
neighboor hood. You need a 4 layer pcb as quoted in the
design notes of this chips (Texas, National, Thine)
If you are a pcb designer with high speed design knowledge
do it. When not , forget about it to do it yourself.
But you can add easilly sound with some wires
at the ISA slot. That's not a problem.
Think about what is easier and cheaper to do.
Perharps you find some ready to fit LVDS transmitter
which you have only to fit in cheap in such a board.
Look for TDMS, LVDS Transmitter modules.
Most XGA displays from 13.3" up have the LVDS receivers included. So you need only the transmitter module.
Pay attention that the module can handle 18 and/or 24 bit colors.
If you have a 14 or 20 pin connector you have an LVDS display.
14 pin = 18 bit (262k colors)
20 pin = 18 / 24 bit (262k or 16.7 Mio colors)
regards
Rainer
is there anything bad about MDF panels? jarthel Multi-Way 3 22nd June 2007 06:47 PM
Page generated in 0.11321 seconds (80.97% PHP - 19.03% MySQL) with 11 queries
