Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 22nd December 2002, 04:36 AM   #311
zardoz is offline zardoz  Canada
Send a message via ICQ to zardoz
Default Rekr
Email sent
Old 22nd December 2002, 04:47 AM   #312
Exclamation windows error
I have been playing around with my setup, and after a couple of questions from a friend have noticed that windows is miss-reporting the screen size that is displaying on my desktop.
I can drive the card at 800X600 32 bit, windows had identified it as a laptop screen @ 1024x768. A simple matter of "telling" windows what was hooked up and it now reports correctly.
It may have something to do with the Duo View feature on the card I really don't know, nonetheless I'm still quite pleased and impressed with life in general
zardoz
Old 22nd December 2002, 05:52 PM   #313
Dnt32 is offline Dnt32  United States
Send a message via Yahoo to Dnt32
Default Condor2
I sent an email To the Evi displays a few days requesting some more info on the product and requested what products I forgot to specify LCD screens(OOPS) screens are compatiable if I dont get a reply maybe some of you more seasoned guys will try to get a response from them.
Doug
Old 27th December 2002, 05:27 AM   #314
Just saw this on Ebay: Compaq 14 inch with ATI
I wonder if we can get those ATi cards to drive other lcds
Rekr
Old 27th December 2002, 09:11 AM   #315
Send a message via AIM to delusion602
Rekr
I haven't seen the specs on that particular model card, but it should be able to drive any display with a DFP input (or DVI with an adapter.)
That's a nice deal on the combo though, assuming the panel is XGA.
Old 27th December 2002, 09:04 PM   #316
Default lcd controller - driver board
Hi guys,
I already posted this on my thread "Does this lcd have controller on it?" so sorry for duplicating things. But since this thread is for this specific topic it would be great to have the explanation under this thread.
I purchased a panel NL10276AC28-01L that has a CRT interface board on it. Is this what is refeered as the lcd controller?
I then saw a simlar NEC lcd panel that lwh is using and his lcd has the same crt interface board but also a second driver board attached.
Do some controllers have both functions or do lcd panels always need both boards. Can somebody explain to me funciton of the two boards. Also, how expensive are driver boards and are they compatible with many crt interface boards.
Final question, wich category does the Spectrah and the evdisplays products come under.
Thanks for any help on this.
Exipnos.
Old 28th December 2002, 04:30 AM   #317
Send a message via AIM to verbose mustafa
Sorry guys if this is a waist of time, but has anyone heard of the "nview viewframe tft" model? I picked on up for 26 bucks on ebay. It looks rather new and is a bright yellow color. I belive it is the same resloution as the spectra c.
-verbstafa
Old 28th December 2002, 06:22 AM   #318
verbosa
I saw a list from another post with all the lcd panel infos for various makes and models, the only thing they had listed for yours was that its 640x480, sorry I couldn't find out more
Rekr
Old 28th December 2002, 06:01 PM   #319
Default LCD's with controller cards.
Post By "uvodee" on page 7.
( how to hook up a 10.4" panel SOLVED
http://cgi.ebay.com/ws/eBayISAPI.dl...&item=801043878
apparently this guy has it solved ........
speechless for now..)
HI guy's this is my first post in this forum...... I've found the manafacture's website http://www.action.com.tw/acv/product2.htm ....now all we need is price's.
I think this will be ideal for a diy projector, if it's not... please tell me why?
BRF.
If your not living on the edge...... Your taking up to much SPACE!
Old 28th December 2002, 06:06 PM   #320
Default LMM 104 lcd specs
SPECIFICATIONS
LMM-104 TYPE
Color LCD PC/VIDEO Module
DISPLAY SCREEN
SIZE 10.4 inchesi211 ~ 158 mm W~H)
ELEMENT TFT-LCD 262,144 Color
FORMAT 640(W) ~480(H) Pixels
LCD PANEL
NEC NL6448AC33-18
BACK LIGHT
Two cold cathode fluorescent lamp
POWER SUPPLY
DC 12V
POWER CONSUMPTION
DC 12 V 15W
PC SYSTEM
VGA
VIDEO CLOCK FREQ.
25 MHz min.
SCANNING FREQ.
H : 31.5 KHZ V: 60-70 HZ
VIDEO SYSTEM
Auto NTSC / PAL / SECAM
BRIGHTNESS LEVEL
200 cd/sqm Typical
CONTRAST LEVEL
150 : 1
VIEWING ANGLE
L/R 45/45 Deg. U/D 30/20 Deg.
INPUT TERMINALS
External power jack(DC IN 12V)
Video 1 input jack (RCA type)
Video 2 input jack (RCA type)
Audio 1 R/L jack (RCA type)
Audio 2 R/L jack (RCA type)
PC input (D-SUB 15 pin)
OPERATION TEMPERATURE
5Ž ~ 40Ž
STORAGE TEMPERATURE
|20Ž ~ {60Ž
DIMENSIONS
PANEL 243 ~ 185~ 11 mm (W~H~D)
DRIVER BOARD 190 ~ 120 ~ 35 mm (W~H~D)
INVERTER BOARD 100~25~10 mm (W~H~D)
WEIGHT
0.7 KG
I hope this helps guy's.
BRF.
is there anything bad about MDF panels? jarthel Multi-Way 3 22nd June 2007 06:47 PM
Page generated in 0.11725 seconds (79.66% PHP - 20.34% MySQL) with 11 queries
