Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 18th December 2002, 02:39 AM   #281
zardoz is offline zardoz  Canada
Send a message via ICQ to zardoz
Default scratching the cover?
Um.. your voiding your waranty and you dont want to scratch the cover? I'd look for maybe a couple of spots that might be glued (look near the middle of long seams) also sometimes there is small "catchs" made of plastic and molded as part of the case, these mate with similar on the opposite side of the case ( I've also seen 1 left hand threaded screw placed amongst all right hand threaded screws, the left hand thread one looks normal but is designed to break when you turn it).
I wouldnt be surprised to see at least one of these methods being used, these units dont usually get "fixed" so dont need to open. If there are "security" features built into the case it's for waranty purposes.
zardoz
Old 18th December 2002, 02:52 AM   #282
jvisaria's Avatar
Send a message via ICQ to jvisaria Send a message via AIM to jvisaria
dont forget to look for hidden screws as well..
if there are any small plastic or rubber pieces, or stickers on the back... poke around.. there may be screws underneath.
Old 18th December 2002, 03:53 AM   #283
nj_tom's Avatar
Default Dismatling Kogi LCD
Thank you guys. I am fired up again. Will start with full speed tomorrow evening. I have to use force...and a lot of that. From the site below which describes every step of it - gave me the feeling that removing the back cover is one of the big hurdles. Anyway, wish me luck.
Check this out for a demo by SuperDave.
http://www.csun.edu/~hbpsy028/projector/
Old 18th December 2002, 01:54 PM   #284
nj_tom's Avatar
Default Finally opened the LCD cover
I couldn't wait till the evening, so i tried today morning. Finally I got the back open. But that would be wrong to say. Even though the the screws seemd to be holding the back cover, they were actually holding the front. There is a trick in opening the Kogi 15" LCD monitor. I don't know if anyone has faced this situation before or not. The front cover actually came out, and i was able to see the front screen of the lcd. There were 8 small latches/knobs which were located around 1.5" to 2" below each corner. The cover was neither glued, nor there are hidden screws.
I have the pictures and I will post it later....maybe in another thread. I haven't yet taken apart the whole LCD. I just took one step at a time. Tonight I will remove the whole thing.
Old 18th December 2002, 03:35 PM   #285
Default Re: Finally opened the LCD cover
Just read through the msgs, I am glad and surprised to see others trying my approach. I did take pictures of the disassembly process and the wires soldered to the boards to move them out of the way. Unfortunately I am being forced out of my apartment at the moment, so I have put my project on hold until I have moved. After I am settled again I will try and post some pictures and project information if someone else hasn't already done this. Not sure I will be much help until then. As for dissemble of the monitor, the screws did release the front, there were also some small plastic clips that need to be carefully released with a screwdriver to remove the front. After that, the rest is all a lot of screws and that aluminum tape. One thing to be careful of is releasing the small flat cable connector that ties the boards connected to the LCD together. I found that if I used a jewelers screwdriver and slid the sides out, the connector came apart easily. I will be interested to see what others do with this project, perhaps it will give me good ideas of how to finish mine.
Old 19th December 2002, 06:38 AM   #286
Dnt32 is offline Dnt32  United States
Send a message via Yahoo to Dnt32
Default Pin connector layout
Have you guys found out the specs for the pin layouts yet if not I have them for the 32 pin,28pin and 20 pin I think.
I havent read thru the entire thread yet I got bored and researched a lil and found this page with a controller that has 3 connectors for 32 , 28, and 20.
BTW Im new I hope these will help in some way.
Well someone will have to tell me how to post these images that i have they are gif
Doug
Old 19th December 2002, 08:50 AM   #287
This is the pics I wanted to put up previous post.
this had no price but it looked as if it was something you guys are looking for it supports sxga,xga,svga,vga lcd tft's and plasma. prolly high priced but the info about the pins maybe be of good use. ntsc/pal
http://www.evdisplays.com/condore.htm
Old 19th December 2002, 08:53 AM   #288
Default I Need Sleep
This is the correct page here not previous
Old 19th December 2002, 03:06 PM   #289
Doug,
Actually that board looks pretty promising, I saw something similar to that on earthlcd.com, but it was going for $399, I wonder how much that particular board costs, and if we would have to buy it in bulk, thye usually don't sell stuff like that in single quantities. Good find though.
Rekr
Old 19th December 2002, 04:02 PM   #290
I emailed the rep from the company for those new contorller boards:
"Jason,
I was looking for some information about the Condor 2 NTSC controller board, such as prices and minimum quantities for purchases?
Doug Malick
Jason Replied:
We have a fifty piece minimum our pricing on the unit with cables is 135.00
There you have it. If we can get 50 guys up in here to make a group buy that wouldn't be so bad.
P.S. Kinda weird that both our names are Doug
is there anything bad about MDF panels? jarthel Multi-Way 3 22nd June 2007 05:47 PM
Page generated in 0.12460 seconds (78.91% PHP - 21.09% MySQL) with 11 queries
