#111 |
so, if you check those pdf files from:
www.lcdspecifications.com and see the pinouts for actual lcd panels, you will see that you can hook up 15/16/18/24 wires from lcd panel (for digital RGB) directly to that conexant chip! all that is left is to figure out which pins on conexant will give sampling clock, data enable, horizontal and vertical syncronisaton signals, and to wire rest of wires to them! no controllers, just some wires and soldering skills! |
#112 | |
1. Advantech sells LVDS transmitters and recievers for PC/104 slots. Those are like "mini PCI" slots for tiny industrial single board computers. What does that mean? It means you'd have to buy an SBC computer. So far your looking at >$500 for something that won't even play Quake 2 (not good for your projector). 2. I have never seen a bare LCD w/ an LVDS reciever built in. You say they do exist. The lower amount of wires for the hinges thing makes sense, but I'd bet if it's true that the newer laptops have the reciever as a seperate component on the panel. But you've looked at the pinouts to different panels so I'll assume your right. Point is that an LVDS reciever from a laptop may not have the same connecter and/or pinouts as the LVDS transmitter that Advantech sells. LVDS is a type of technology, not a plug n play standard like DVI. Finding the pinout (the laptop's manufacturers in Asia will be the only ones who know it for sure) and making a custom external cable will be a huge pain. And matching pinouts might even not matter because the signals for the transmitter and reciever could be totally different. 3. Even if you did match up the pinouts and it worked, what about the bios? What about the brightness, size, and contrast controls? What about on/off? Only the laptop's mobo knows how to do that. 4. If you have a DVD decoder or a TV tuner, forget about it because you need a 15 pin VGA loopthrough for it to work. Suddenly, the unnoticable signal loss through analog VGA doesn't sound so bad. 5. Getting a VGA--->FPD converter (D/A converter) costs a lot less, is a lot easier, and solves the problems from #'s 3 & 4 above. No soldering, splicing, or buying expensive components to make proprietary hardware work with other proprietary hardware. Getting a laptop panel to work on a regular PC is not difficult. Your taking the wrong approach is all I'm saying. Get the model # of you panel, call earthlcd.com (they're in San Diego) and tell them you want a VGA converter for it. If they don't have that model on file, give them the pinout and they'll take care of the rest. Simple as that. |
#113 |
Ok, nobody seems to be listening to me. Years ago a bunch of guys on a message board wanted an LCD screen in our cars. We went through what you guys did back in 1999. Look:
http://www.mp3car.com/vbulletin/show...+Color+Screens A huge thread that looks just like this one - from 3 years ago. Skim through it. That's when I went on the same mission remp is on. |
#114 | ||
Why is everyone too lazy to read my posts?
Analog, digital- take your pick. That's as reasonable as it gets. End of story. $199 for the EarthVision/ADC is not that bad, especially if the panel is less than $50. If you can find LCD desktop monitors (with a good enough resolution, contrast ratio, and response time) for $250 or less than it's worthless. Buying an LVDS controller is not going to be less than $199. Even if you magically found one for $100, saving $99 is not worth the pain it would be to match up the pinouts and make a cable. I'm waiting till I can find and buy a D/A converter that works for 1280x1024 panels (the Earth ones only support XGA). I've seen them around but the companies sell to businesses in bulk only. Then I'm going to by a 1280x1024 panel on ebay. $200 for the controller, $150 for the OHP, and anywhere from $100-300 for the panel. That's $450-650 for a high definition VGA projector. Not bad at all. |
#115 |
I realize that you've been down this road before and checked all these possibilities before, and I hate the thought of this forum rehashing leads that have been exhausted before. But in the forum's defense, things could have changed in this situation since 1999. Maybe this IS a dead-end issue, but you never know where something like this might lead and if someone is willing to keep investigating and trying, they may just come up with a possible, inexpensive solution. I think you're right (and far more knowledgeable than me on the subject!) that there comes a point in which "diy" is a lot more trouble and expense than just going out and buying the right components from Earthlink, but where's the harm in trying? How many "cold case crimes" have been solved just by letting someone fresh look at the data? Its never a waste of time as long as you're gaining knowledge from the search....and I am.
#116 |
I have been monitoring these forums for a while, lots of good info. I just bought a flat screen monitor from Best Buy for $220 (after rebate) with the intention of converting it into a projector. I got the KOGi 14.1" screen and took it apart. It had what I expected to find, two boards one on the top and one on the side of the screen which were connected via a little flat brown cable. The cable had 16 connections on it, but on closer inspection, I discovered many are duplicates, and only 8 wires are really needed. I soldered tiny wire wrapping wire directly to both circuit boards (this was not easy and not for the faint of heart), ignoring the flat cable. I moved the boards out of the way, put this on an overhead projector (just to test, think I will build it into a better box eventually) and turned it on. I was treated to a very nice (1024 X 768) looking picture of my windows screen on my wall. I am wondering if anyone else has taken this approach, it only took me a few hours to add the wires. Perhaps I am missing something that is bad about this setup?
#117 |
Account Disabled
Yander26
Any way at all to advance the technology is good. Using monitors has been tried in the past. Some with success, but also some failures. As you said its not an easy job repositioning the boards but you have got a good result. What inputs does your monitor have. Video, computer. ? You have not missed anything at all. A good solution. Be good if anyone could find a 10 inch monitor. |
#118 |
The monitor only has VGA input, but I have a computer with a TV tuner and a DVD player. I have heard of devices from these forums that convert from RCA and S-video to VGA, so depending on the quality of those, I might give that a try. Actually I see that Best Buy sells one with a TV tuner in it for $130 considering I can return it if I don't like the quality I can give that a try. I was able to get the LCD display to fit in it's entirety on the overhead by taking apart the glass top of the overhead, and cutting the plastic away between the glass and the fresnel lens. It seems to work fine, I was worried the fresnel lens ended under the plastic but that wasn't the case, and it looks fine at the edges. So far the only down side I see to it being a 14" monitor is that the projector will be physically larger. If I decide to use the overhead, it won't make any difference, as it will be the size of the overhead projector.
#119 |
Account Disabled
Yander26
I thought the 14.1 inch monitor would have been too large for a conventional OHP but your solution overcomes that problem. You have posted a brilliant solution which I am sure others will try as well Just to run over it. LCD monitor KOGi 14.1 inch $220 US from best buy (after rebate) Fits on an OHP with Yander26 modification. Takes in VGA Had a problem shifting two boards out of the way which Yander26 solved by skillful soldering. People not willing to do the soldering look at maddog thread. He also mentioned a little brown cable and posted some pictures. Uvodee gave good info on where to obtain longer connector cable (Molex) |
#120 |
FYI.
http://www.softwareandstuff.com/h_mon_unisys105lcd.html Unisys 10.5" LCD Monitor w/ 4MB PCI Video Card $119.95 Specifications -10.5" Viewable screen -Maximum resolution-800x600(1024x768 can be displayed in virtual monitor mode) -Maximum Colors displayed-16 Million -4MB PCI Video Card(Plug & play in Windows 98 SE and above), supports dual monitor mode (PLEASE NOTE: THIS MONITOR WORKS ONLY WITH THE SUPPLIED VIDEO CARD -Adjustable monitor neck |
| is there anything bad about MDF panels? | jarthel | Multi-Way | 3 | 22nd June 2007 06:47 PM |
| Page generated in 0.17512 seconds (88.18% PHP - 11.82% MySQL) with 11 queries |
