Go Back   Home > Forums > > > >
I got my new lamp. It is for commercial projection use. people use it to replace the
Old 23rd February 2010, 12:25 AM   #2671
ywh is offline ywh
Send a message via MSN to ywh
Hi Nick325i !
you need 130w BSM-AC, $89 total.
Hi vincent666 !
you have under 100 lumens maybe if you can not fit the arc in the focus of reflctor, you can send them to me to rebuild
Give up the UHP and HQI lamp now! Take a look at our LED projector!!http://www.diyaudio.com/forums/diy-p...e-theater.html
Old 23rd February 2010, 12:55 AM   #2672
betelnut is offline betelnut  United States
Hi, folks,
I did a little write-up of how I did my bulb replacement for a 3M MP8650. It went well so far, but I've only run the projector for an hour. We'll see whether my choice of cement works or not, and whether I messed anything else up.
Please comment if there are any mistakes, or any improvements I should make. Thanks!
computing Blog Archive Cheap projector bulb replacement
Old 23rd February 2010, 03:26 AM   #2673
giorgos18 is offline giorgos18  South Africa
Thanks for that Blog! I read it and posted a comment
Very nicely done!
Old 23rd February 2010, 10:54 AM   #2674
jefflynne is offline jefflynne  Czech Republic
Default bulb
Hi ywh,
I need a bulb with reflector to my Epson EMP 50. Its 150W 70V. Do you have any?
Jeff
Old 23rd February 2010, 11:57 AM   #2675
Thanks, giorgios18! YWH gave me his approval, so I'm leaving the blog entry up. I'll update it with any good ideas you folks send, or in case I run into any problems with my job down the road.
Old 25th February 2010, 06:56 AM   #2676
midge332 is offline midge332  United Kingdom
ok first post here goes hello everyone picked up a faulty sanyo from ebay lamp turns off after 20 secs so looking for price for replacement shipped to uk for plc-xu40 which runs on an euc 180 a/01 ballast specs say 180w lamp but on the lamp it says 150w ,has the wrong lamp been inserted
Old 5th March 2010, 06:34 AM   #2677
vincent666 is offline vincent666  France
Hello Ywh,
I dissasembly my lamp and i see that the bulb is coming black inside, i don't know why
but i think this black color causing the low light ouput problem...
what can i do know ?
I have to posting photos of the problem...
regards,
Vincent
Old 5th March 2010, 12:42 PM   #2678
Bohanna is offline Bohanna  United States
Hello,,, It Might just be the lamp The ballasts don't go to often in the Sanyos and I think the 180W is the correct ballast. The Lamps are VERY finiky in the sanyos!! I have several Lamps that look BRAND new and they won't make it past the screen power up / countdown or if they do they last a short while and the projector shuts down. I have tried the new looking lamps in several of the same model projectors with the same results. They don't make a 185 Watt UHP lamp for the sanyo's they make a 150 and a 200 so my guess is it's your lamp. To test the ballast you can use a 150 watt ventura metal halide scabbed outside of the projector to see if it stays on . This will let you know if it is the ballast of the optical sensor circut.
make sure if you try the outside lamp test tyhat you have some sort of fan blowing air buy it and MAKE SURE you have some serious sun glasses or a welding mask on.
DO NOT LOOK AT THE LAMP WITH OUT EYE PROTECTION!!!
Good Luck
Bohanna
Old 9th March 2010, 05:28 PM   #2679
thanks for the info managed to get it working,i took a 150w ballast out of a sanyo plc-sw20a that had no lamp and fitted it into the plc-xu40 and used a 120w lamp from a busted ezpro 615h which used the same ballast but slightly larger(i fixed power supply but couldnt get it to display an image),am very pleased with the results
Old 10th March 2010, 01:12 PM   #2680
ywh is offline ywh
Hi jefflynne!
you need 150w BSM-DC, total is $89
Hi vincent666 !
I can not find your e-mail with Vincent , what is your email ? what is your projector?
I got my new lamp. It is for commercial projection use. people use it to replace theHide this!Advertise here!
Copyright ©1999-2017 diyAudio
