Go Back   Home > Forums > > > >
I got my new lamp. It is for commercial projection use. people use it to replace the
Old 16th June 2005, 02:03 PM   #11
18wheeler is offline 18wheeler  United States
Send a message via MSN to 18wheeler
Originally posted by Megaman
That bulb is a double ended one. It can not be put in an ellipsoidal reflector.
like this:
Old 16th June 2005, 11:06 PM   #12
F2 - F1 distance is 130mm in my reflector. this lamp is 8-9cm total. put the light center at F1. it goes to additiional 45mm. it is far from the F2. just use a thin wire to connect to that end, like comercial lamps do.
Old 17th June 2005, 03:51 PM   #13
ywh is offline ywh
Send a message via MSN to ywh
I have asked. The ballast could convert to 100V-240V wide range by
replacing one of the IC chip. It costs additional ~$4. But the
manufacturer need 10 mininum order to make such change.
Old 18th June 2005, 12:07 AM   #14
shlomid is offline shlomid  Israel
Default where can I order this lamp?
Old 18th June 2005, 12:48 AM   #15
Lightbulb BTW
you can buy 300W transformer
or You can buy 4 units of 220 to 110 transformer- 70W
for about 12$ each (or less)
join them in parallel in a box and you will have 280W transformer !
(you can add one more for 350W)
Shlomi
Old 18th June 2005, 02:25 AM   #16
Default Re: BTW
Originally posted by shlomid
After chatted with YWH. I think I would go ahead and start a group buy for this lamp / ballast, as long as I can geither other 9 people.
Shlomi
since adding $4 we can get 110V version. I would rather go that route.
Old 18th June 2005, 02:42 AM   #17
agent.5 is offline agent.5  United States
It may be helpful to the groupbuy if someone with more experience can provide links to other items (e.g. reflectors, filters, etc) that can be used with this lamp.
Old 18th June 2005, 03:20 AM   #18
let's see what YWH uses in his setup. I believe we can copy his design and get same items as his.
common setup would be put light center between a spherical reflector and a condensor. the same design is used in the most OHP's
Old 18th June 2005, 06:25 AM   #19
Mikey p is offline Mikey p  Canada
The specs of the bulb list everything except the lumen output. Anybody know what it is?
Old 18th June 2005, 09:27 AM   #20
ywh is offline ywh
I have asked, the luminous flux:
20000 lumen
I got my new lamp. It is for commercial projection use. people use it to replace theHide this!Advertise here!
