I got my new lamp. It is for commercial projection use. people use it to replace the I got my new lamp. It is for commercial projection use. people use it to replace the - Page 178 - diyAudio
Go Back   Home > Forums > > > >
Old 24th March 2008, 02:34 AM   #1771
turboto is offline turboto  United States
Hi YWH !
What bulb do I need for the Infocus X2 PROJECTOR . Is it your
200W BSM-DC . Thanks for the help.
Old 24th March 2008, 03:50 AM   #1772
ywh is offline ywh
Send a message via MSN to ywh
Hi budzz11009 !
I need your address
Hi turboto !
you are right! you need 200W BSM-DC
Give up the UHP and HQI lamp now! Take a look at our LED projector!!http://www.diyaudio.com/forums/diy-p...e-theater.html
Old 24th March 2008, 07:40 AM   #1773
X_Online is offline X_Online  United States
Default Re: tengo reemplazo para lampara uhp
Originally posted by markopalo
Hola, tengo reemplazos de lamparas uhp sin el reflector en potencias de 150w y 200w
Caracteristicas http://www.xenon-lamp.com/videolamp.pdf
te puedo dar opciones y consejos de como armar las lamparas
y tambien ayuda con proyectores
estoy en sudamerica y exactamente en argentina
el costo es de u$s200
en argentina el envio es sin cargo
para consultas markopalo@hotmail.com
Porque son tan caros?? es mucho dinero no??
Old 24th March 2008, 09:05 AM   #1774
erucoco is offline erucoco  Spain
Hi YWH
I'm using a 280W/DC JYs-SE lamp, and it doesn't start with this lamp. I buyed it in diypro.us.
Are you saing that I have to buy an HQI instead of the one you sell?
Please give me some tips, I wanto to use the one I buyed to you. A 280W/DC JYs-SE lamp.
regards
Old 24th March 2008, 09:14 PM   #1775
budzz11009 is offline budzz11009  United States
YWH
I did send you email from frank11009@yahoo.com for my mail address
thanks
Old 25th March 2008, 01:38 AM   #1776
ywh is offline ywh
Hi erucoco !
send a clear pic of your bulb to yuweihua@163.net, I need this to ask new bulb.
Hi budzz11009 !
OK ! sent!
Old 25th March 2008, 03:30 PM   #1777
rorr is offline rorr  Czech Republic
Default CXD 3500R
Hello YWH,
I have one another question. For a long time I am looking for SONY chip CXD3500R. It is timing generator for LCD in projectors. I want this chip for projector COMPAQ MP1200, where is burned. Have you any idea where I can get it? It is probably out of production.
Thaks a lot !
Old 25th March 2008, 04:16 PM   #1778
anachronous_one is offline anachronous_one  United States
Hi yhw,
I've got a BenQ PB 6200 with a really awful flicker that results in part of the image being duplicated in the lower extremes of the image. I'm hoping that a replacement bulb might be the key?
This is my first pj and first dlp device, so I'm not sure if I'm looking at an issue with the bulb, reflector, or the color wheel.
Could you send me a quote on a replacement bulb as well as a seperate quote based on you replacing the bulb for me if I were to send you my old lamp assembly?
section8 AT wingsisp DOT com
Thanks!
Old 25th March 2008, 05:58 PM   #1779
Originally posted by anachronous_one
Hi yhw,
Thanks!
Hallo anachronous_one,
At first, im not english spoken person, so im not sure, if will be clear, what I mean.
I have also this projector, in the concrete BENQ PB6210. It is also DLP based projector. I must say one important think for you. In the DLP based projectors, the lamp not working in the continuous mode, but blink in synchronism with the color weel. So when is the relevant color of the wheel in the right position, then the lamp is switched on. It is similar like mechanical shutter weel of mechanic projector, but here this function is realised by switching on and off the lamp. For sync. signal is used small sensor mounted on the color wheel and by two wires connected to lamp ballast. Here may be your problem, your lamp is not triggered by this sensor in right possiton and/or sync. not working properly. Im not sure if this problem is yours, but I advise You to check this sensor. Very quick and easy but rough test if the sync. woking properly,is breake your rotating color wheel by your finger. If the lamp will starts blinking with slowest cycle and in the end stops working with standing wheel, the sync is working. But it is dangerous test for the lamp and ballast .
Another problem may be in synchronisation of video signal on the imput of the projector.
Old 25th March 2008, 06:35 PM   #1780
OK, I greatly appreciate your input and advice. If I understand correctly, you recommend that I stop the color wheel with my finger and see if the lamp slows down the frequency of flashes until it completely stops. Is that right?
Your final sentence makes me think that I might be risking damage to the lamp and ballast if I attempt this test. Do I understand you correctly?
I got my new lamp. It is for commercial projection use. people use it to replace theHide this!Advertise here!
Copyright ©1999-2017 diyAudio
