Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 14th June 2005, 01:47 PM   #1
ywh is offline ywh
Send a message via MSN to ywh
Default I got my new lamp. It is for commercial projection use. people use it to replace the
I got my new lamp. It is for commercial projection use. people use it to replace the bulb in the commercial projector's lamp (the "light" part, the refelctor is kept).
Here is some specs:
wattage: 250W
arc length < 4mm
color temp: 6500K
life span: > 2500hr (replacing, not failure time)
ballast: integrated electronic ballast
I am going to replace my OSRAM HQI 5000K. I will post result in a few
days and compare to the HQI.
Old 14th June 2005, 01:50 PM   #2
Send a message via MSN to 18wheeler
Wow! it is a wonderful lamp. how much did you pay for it? how heavy is the ballast? can the ballast be used in US (110V) ?
Old 14th June 2005, 01:52 PM   #3
ywh is offline ywh
Default arc length < 4mm
arc length < 4mm
Old 14th June 2005, 02:45 PM   #4
Dazzzla is offline Dazzzla  Australia
Probably expensive
DJ
Old 14th June 2005, 03:41 PM   #5
Default Re: arc length < 4mm
Originally posted by ywh
arc length < 4mm
reading 3.7mm! it is the shortest that used in a DIY projector I have ever seen.
Originally posted by Dazzzla
Probably expensive
DJ
right. but YWH always gets great parts/price. I hope it's the same this time too
Old 15th June 2005, 12:54 PM   #6
ywh is offline ywh
I paid about $120 for the whole set. It is cheaper
than a HQI setup.
The ballast is 220V, but the manufacturer told me they can make it 110V if I special order a bunch. It weights about 500g, not as heavy as core and coil type ballasts.
Old 15th June 2005, 05:24 PM   #7
Old 15th June 2005, 11:01 PM   #8
I paid about $120 for the whole set. It is cheaper than a HQI setup. The ballast is 220V, but the manufacturer told me they can make it 110V if I special order a bunch. It weights about 500g, not as heavy as core and coil type ballasts.
I want one too!!
how many sets is the minimum order to have the manufacturer re-model the ballast to accept 110V? I am seriously considering a group buy for this 250W lamp / ballast. anyone else care to join? YWH, I will send you an email about this.
how about your NEC XGA LCD? have you solved FFC problem? it would be a killer setup to use this 250W lamp + ellipsoidal reflector + 6.3" XGA LCD.
Old 16th June 2005, 07:26 AM   #9
Megaman is offline Megaman  Sweden
That bulb is a double ended one. It can not be put in an ellipsoidal reflector.
Do you know how many lumens it sends out?
As for the LCD, I'm also interested.
Old 16th June 2005, 12:59 PM   #10
ywh is offline ywh
I want one too!!
I am gong to ask the manufacturer .........
change a small screw capin one ended, connect the wire,other ended is setscrew,it can be put in an ellipsoidal reflector.
Page generated in 0.12070 seconds (79.60% PHP - 20.40% MySQL) with 11 queries
