Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 5th February 2010, 11:23 AM   #2661
lis is offline lis
ywh
Please tell us what technical data from this lamp
Old 8th February 2010, 02:20 PM   #2662
ywh is offline ywh
Send a message via MSN to ywh
Hi Babyjesus!
a 200w lamp run in 180w ballast is a 180w lamp ;-) , the ballast control the power
Give up the UHP and HQI lamp now! Take a look at our LED projector!!http://www.diyaudio.com/forums/diy-p...e-theater.html
Old 10th February 2010, 01:12 PM   #2663
Default i received my lamp but.......
dear ywh,
i received you Jys DC lamp at 200W, put in my opotma DS309 but after long
time adjusting the focus..i didn't have enought light...i'm far away original.
it seem that the ballast have difficult to light on the lamp...and sometime
the light flashing to good result but come back to bad result...it seems
that the ballast try to goes to 200W but come back to 180W...
it is possible to adjust the ballast power ?
regards,
Vincent
Old 15th February 2010, 12:53 PM   #2664
ywh is offline ywh
Hi vincent666 !
the cheaper JYS burner is $60 brightness as original. that will lost more brightness fi you can not found the focus
my BSM-DC is same as original.but need $80 each
Old 15th February 2010, 06:48 PM   #2665
Evolvo is offline Evolvo  United States
Default Wow.
From what I understand you sale replacement bulbs and give info on how to use existing bulb enclosures to install a new bulb?
Do you sale a generic form of bulb and how does it compare to the original? Same hours or more?
I'm looking for a Epson Home Cinema 720 Bulb (V13H010L39)
It's a UHE-170E2-C
170 W
80V
Are you replacing whole housing unit or just bulb?
Sorry so many questions?
Old 16th February 2010, 04:49 AM   #2666
Could you also tell me what would need to be done to install this bulb any special ballast or anything. Do you have a website.
Old 18th February 2010, 12:36 AM   #2667
Default Compaq MP1600
Just got a Compaq MP1600 off of craigslist, $15, advertised with a bad bulb. Took it home and was surprised to find it seemed to work fine. Watched a whole hour last night.
Today it went on for about 5 minutes and shut off. Now the LEDs in the buttons blink every second or so and at the same time makes a short, high-pitched squeak (wonder if it's trying to ignite?). Every once in a while it'll start to turn on (fan starts up), then shut off immediately.
Projector said 300 or so hours on the bulb, but that could have been reset.
Would YWH's new bulb fix this, or is there a good chance I'm throwing away my money?
Old 18th February 2010, 01:16 PM   #2668
ywh is offline ywh
Hi Evolvo !
you need my 170w BSM-AC burner, $89 total, please send a email to me ,so I can send more inf to you
Hi betelnut
I have new burner, but your projector was so cheaper
Old 20th February 2010, 12:03 PM   #2669
Hi! I need lamp for Panasonic PT-AE700E. Original lamp (HS120AR10-4D as stated on reflector, 130 UHM as stated in operation manual) blown on 750h.
Old 22nd February 2010, 02:33 PM   #2670
""Hi vincent666 !
""the cheaper JYS burner is $60 brightness as original. that will lost
""more brightness fi you can not found the focus
""my BSM-DC is same as original.but need $80 each
Yes i know that but originally it has 2000 lumens...with this new bulb
it is difficult to see it into total black room
With your bulb i hoping to have about 1000 Lumens...but i think i
have under 100 lumens.
I make photo and post it on this forum !
regards,
Vincent
Page generated in 0.12981 seconds (73.94% PHP - 26.06% MySQL) with 11 queries
