#1891 |
Ok, maybe it works, thanks
what material is the "basic wire" which comes with the lamp ??
#1892 |
Wow, a lot of good and informative info contained in this thread.
I was just wondering if anyone in the States has been able to track down a replacement arc tube for a Sharp AN XR10X lamp? Yhw said he has some functional lamps but will only illuminate 70% or so of OEM. Any ideas? I know they're out there since a couple Co's are re-lamping them, but haven't been able track them down yet. |
#1893 |
Ok, I solved the problem using ywh method, but more smaller.
So i broke this basic pc cable and used little "thing" inside it to connet the wires. |
#1894 |
Hi Ri7 , can you please give me a mail to ask some cuestions directly to you? thanks
Olá, Ri7, tudo bem? sou de argentina e queria saber se podes-me dar faz favor, um mail para fazer-te um par de consultas directamente a vos, obrigado e sorte Hola Ri7, todo barbaro? yo soy de argentina, disculpa que te moleste pero queria saber si me podes dar un mail para hacerte unas preguntas especificas , te lo voy a agradecer, hasta luego y suerte |
#1895 |
Ywh, do you sell ballasts and lamps?
#1896 |
Hi YWH,
I need to replace a lamp in my Sanyo PLV-Z1. Original lamp is 132W UHP. Do I need 130w BSM-AC as an replacement, how much is it and where do I sand the money? I'm located in Canada. |
#1897 |
ywh,
I'm finishing up setting up my money bookers account. Just waiting for the credit card verification part. I'm gonna buy a 150w BSM-AC from you. Didn't know how to go about getting you my shipping information. Do I do it when I send you the money over moneybookers? Also, is the bulb still 80 plus 5 dollars shipping? Thanks. |
#1898 |
diypro.us
#1899 |
Hi guys,
I have an Infocus LP530 with an ageing lamp and I was thinking of trying to replace the bulb in an old lamp module that I kept. The thing is that my projector has had a power supply upgrade (now takes SP-LAMP-LP5F rather than old SP-LAMP-LP5E) and apparently that changes the bulb ignition voltage. But the bulbs that are listed on diypro do not talk about ignition voltages so how do I tell what is suitable? Also, if ignition voltage of stock bulb can be assumed to be OK, diypro shows 250W or 280W options for the JYs-SE/DC bulb, but the LP530 specifies 270W. Would 280W bulb be OK to use or do I need something else? And finally there is a post earlier saying that YWH sourced lamps do not work reliably in the LP530 and will cause the power supply to fail. Is this talking about the pre-modified power supply having too low an ignitin voltage for these bulbs, or some other problem? Thanks for your help. |
#1900 |
Hi ! zeims
"basic wire" is made from titanium alloy. Hi !Bizarro yes! what is your need? give me picture Hi !Cyclop price is $80, shipping is $5. Hi !samseide yes! the bulb is still 80 plus 5 dollars shipping.send your address to my email address Hi phimay 250~280 are same, dont bother. I have found this problem, they are 2 type ignition voltages , my lamp can not start first, but now I have done other low ignition voltages JYs-DC bulb, no problem now. they are low ignition voltages ballast and high ignition voltages ballast
Give up the UHP and HQI lamp now! Take a look at our LED projector!!http://www.diyaudio.com/forums/diy-p...e-theater.html |
| Page generated in 0.13048 seconds (73.02% PHP - 26.98% MySQL) with 11 queries |
