I got my new lamp. It is for commercial projection use. people use it to replace the - Page 103 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 15th January 2007, 01:37 PM   #1021
i have a 120w UHP running in a 120W UHE projector.
so they are very close, if not the same. both are AC.
Old 15th January 2007, 01:42 PM   #1022
Hi mbates14
Yes I have seen several references to them being the same .
Just wasn't too sure and hate to roll the dice on a $65.00 bulb.
I'm leaning towards going with it since I have two lamps to do.
How long have you been running it?
Old 15th January 2007, 02:47 PM   #1023
jck is offline jck  United States
Hi ywh,
I'm not sure what you meant about the ceramic comment above. Is the ceramic cement included with the lamp?
jck
jck
Old 15th January 2007, 04:32 PM   #1024
ywh, fyi,
I just sent $65 to 18wheeler via paypal.
Thanks!
jck
Old 15th January 2007, 07:08 PM   #1025
mrpman is offline mrpman  United States
Hey Guys, I am A newbe, GREAT THREAD...
I am trying to avoid spending $400 to replace the Lamp Assembly in my Benq PE8700+
The details written on the Bulb are as follows:
NSH210BQA
325072205
GH2739
60.J2104.CG1
I know the Last number is the Benq Part #. It is supposed to be a 210W bulb.
Does anyone have any info on this assembly? Has anyone replaced just the bulb?
I know I am a newbe, but after reading a little this is what I have gathered so far as to the pieces of a lamp system:
Lamp Housing/Assembly
Reflector Housing/Assembly
Actual "Bulb" inside reflector assembly
You get a "Bulb" from ywh, soak the ceramic end of the reflecot housing, remove the old "bulb" put the new one in and reglue.
Sounds like a great plan to me, where do I sign up!!!!!!!!!
Old 16th January 2007, 01:45 AM   #1026
to ywh
hey i just ordered a 150w epson 7250
i think it is 150w uhe or uhp it seems that both will work
would you happen to know the price for a bulb that is already mounted in the reflector
If you dont know if it will work, try it anyway. benji
Old 16th January 2007, 02:00 PM   #1027
ywh is offline ywh
Send a message via MSN to ywh
Hi mbates14!
I know they are very close, both are AC. but I have never seen a UHE.
Hi jck
I can give your cement , if you ask.
are you Judson? from Illinois? speak Algonquian language :-)
Hi mrpman
you need a 210w NSH, it is a DC bulb, I dont like replace NSH;-)
I have the DC bulb only 180w, It can run 210w but I wrong about the life.
Hi part2wanksta
it is UHP, it is easy to replace.
do you need a original lamp kit? the price of lamp kit is $150, include shipping. no cage
http://hepweb.rl.ac.uk/PPEP/exhibits...tor/manual.pdf
Give up the UHP and HQI lamp now! Take a look at our LED projector!!http://www.diyaudio.com/forums/diy-p...e-theater.html
Old 16th January 2007, 06:06 PM   #1028
Originally posted by Joepapa
Hi all,
Victor!
How did you remove the glass panel from the front of the tube?
My Sanyo Z1's bulb has a very solid glass in front of the tube and
I see nothing else that holds it on the bulb, as some kind of a thin white isolation/insulation rubber strip or something similar underneath. I have no idea how to remove it without applying brut force.
Any idea anybody else ?
Joepapa
Joepapa, Did you ever successfully replace your Z1 bulb? If so how are the results?
I tried to PM you I don't have enough Posts yet so I figured I would post the question.
Old 16th January 2007, 07:06 PM   #1029
Hi BoomerBrian,
As a partial answer to your question on if you are trying to get that front panel off is using a single edge razor blade / exacto knife or whatever thin sharp tool is trim as much of the adhesive off around the panel as you can and work your way around it prying gently I did mine using the single edge razor blade as it's fairly thick and could pry (gently ) .
I was a bit nervous doing mine on my Epson 52c which has that panel on the front but with patience worked it around and it popped off of the reflector. I was a happy guy there.
On your inquiry if the results on replacing the lamp will be the same picture quality. I suppose it would depend on a few variables like if installed correctly , condition of the reflector and front cover/ filter, having the correct bulb in which ywh may help you with there if he has the proper info from you.
To me personally ,it's definitely worth a shot considering the alternatives.
Sorry I can't help you much more on answering your question.
Old 16th January 2007, 08:30 PM   #1030
Originally posted by Dumbfounded
Hi BoomerBrian,
Thanks for the response. I have skimmed through all of the pages and I don't really see anyone talking about their results. I may have missed it but I didn't see it.
I am very interested in doing this but was wanting to know other peoples experiences first.
Copyright 1999-2017 diyAudio
