Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 27th May 2005, 04:05 PM   #21
Send a message via MSN to nick[x1]
In my openion a good 5" - 7" lcd at 4:3 would be great.
As I find the smaller things get the harder it is to build them up. Like with my 15" projector, its so easy to build because its huge. My 7" was quite hard but it was ok to build.
I would be in on a 5" 1280x1024 res lcd that would be amazing
Old 27th May 2005, 04:09 PM   #22
Me2! is offline Me2!  Canada
Me2!'s Avatar
15" not 19". I wish I could use 19" because they are making some very nice panels for that size. Like you say there are problems with too big. 15" is a good balance.
Old 29th May 2005, 06:29 PM   #23
ace3000_1's Avatar
Send a message via Yahoo to ace3000_1
15inch is still miles too big, so is a 7, (7 is over the border line of a 5inch). personally, nothing larger then a 4 is ideal.
Trev
"Every technique can be used in a great many ways, but mastering it, thats what realy counts."
Old 29th May 2005, 07:17 PM   #24
Me2!'s Avatar
This thread is about LCD not dmd. Noone is going to find tiny lcds at high res. and even if they did they wouldnt last long so i don't see why you are encouraging this.
I had a look at the dmd distributer and they want $10,000 for the discovery kit. I guess you are not going to make a dmd system but change lamps on ebay projectors?
Old 29th May 2005, 08:16 PM   #25
ace3000_1's Avatar
Me2, im not going on about DMD's here at all, im going on about my past experience with lcd's and their capabilities in an honest manner, to save you guys wasting time and money on things that wont work how you wished.
If you take a look around you can get high reso small lcd these days for about $700, - that will give you the kind of picture that you are after in the diy world. Honestly, its cheaper to just go out and buy a used projector and just retro out the bulb, both DMD and LCD. The large companies that manufacture pro projectors buy these lcds in bulk, therfore they get these cheaper and most of the time their lcds are worth $3k each!!!!. So ask yourself this: whats more viable, buy a projector without a bulb thats got exspensive panels in it and just retro the bulb, or should i go out and buy a 15inch panel, light source ect and only have 1/3 of the result for the same price?
3 lcd panel projectors in xga reso can be had for as low as $200 on ebay with a busted bulb. Ive even seen some that still have working bulbs for this price and work fine, no color issues ect and have a reasonable contrast.
While you may think retrofitting isnt exactly diy........... well in a way it is and in a way it isnt. The chances of just placing a bulb in the light engine and turning it on are slim (on nothing too old). A typical rebuild of the projector (quite easily done) will have to be done on most models, and lining up the light source in the optics engine is half of the fun .
Price vs performance ratio is what its about. If we wer all rich, lets face it, we wouldnt be in here. Now days, to me, it seems more viable to retrofit a pro projector (that has all correct optics, prisims, lenses, lcd's ect, with a higher performance), then to build one from scratch.
Trev
Old 31st May 2005, 02:14 AM   #26
this is about lcd. experience has shown us buy, not build. so what the hell are we doing here people. ...well some might say finding the perfect lcd is like finding the perfect woman! you just have to keep searching, and even though you think you find the right one (lilliput) the perfect ones around the corner (1600x1200@85 <5msec 5" @£50)
lets stop talking about it and do something about it!
Old 4th June 2005, 08:12 AM   #27
ywh is offline ywh
Send a message via MSN to ywh
Default i have seen it
i have seen the lcd,
i can not extend the filmy cable, too hard!!
the cable is double row lattice,
Old 4th June 2005, 10:19 AM   #28
Me2!'s Avatar
I think that translates to you stripped a monitor and your fcc cable was 2 short?
Old 12th June 2005, 03:02 AM   #29
ywh is offline ywh
Default The FFC of NEC 6.3
I have contacted a local shop that speciallized in extending FFC cables.
They can cut the cable and then solder thin wires to extend FFC. It's
tidious and labor intensive. good thing is labor is inexpensive here.
Old 12th June 2005, 03:08 AM   #30
ywh is offline ywh
On chinese DIY market, a whole set of DIY parts for EZpro serie LCD
projectors is available, including lens, fresnels, mirrors, even steel
cases. EZpro projectors use 6.4" LCD. It is very easy to use those
parts on the 6.3" NEC LCD. and best of all, all optics are matched.
Once FFC extension problem solved I will make one base on this XGA
LCD.
Page generated in 0.12402 seconds (83.45% PHP - 16.55% MySQL) with 10 queries
