Go Back   Home > Forums > General Interest > Everything Else > The Moving Image > DIY Projectors
Old 30th March 2005, 12:06 AM   #1
Default Shortening collector focal length
Could some one please explain to me why the focal length before the condensor is reduced and not after the collector in a unsplit fresnel configuration. You would think it should affect either side of the fresnel resulting in a shorter focal length on the collector side as well. How could Focal length after the collector fresnel be shortened apart from going for a shorter focal length Collector fresnel or by folding the optic patch?
Old 30th March 2005, 03:59 PM   #2
Rox is offline Rox  Spain
Rox's Avatar
i don´t know what are you asking at all .
when you have rear fresnell and front frsenell, you can consider like if you had 1 fresnell. The focal of this new fresnell deppends on the other two focals.
lets say you have 220/330 dual fresnell from a ÖHP, then it is lke if you had 132mm focal 1 frresnell.
you can place a bulb at diferent distances from this new equivalent lens, each distance will focus the light at each associated distance at other side.
allways is the same formulae; 1/F=1/d1 + 1/d2
d1, d2 distances and F the focal of the lens.
Old 30th March 2005, 07:04 PM   #3
So does that mean this theory is incorrect??
http://s6.invisionfree.com/diyprojec...p?showtopic=35
There it says that only before the unsplit fresnel lens it will shorten but not after the unsplit fresnel lens. Any comments???
Old 30th March 2005, 07:11 PM   #4
Rox's Avatar
sorry link does not work
Page generated in 0.06277 seconds (74.67% PHP - 25.33% MySQL) with 10 queries
