i need a ir filter and i need to know if water is the ir filter and it is absorbing ir how long will it take the water to boil
#2 |
6m 53s
#3 |
No, your wrong, its 5min 42sec.
nada |
#4 | |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
I've been watching it since your post, and it doesn't seem to boil. Damn city water.
#6 |
Wait, what's your Altitude?
#7 |
More important that altitude is the question...Are you using a gas or electric stove?
#8 |
lol lol lol
i mean if i was to use water in a 12 by 12 enclosure how long will it take to boil with just the ir heat from a 400w bulb going through it |
#9 |
specific heat of water is 4.2J/K/ml
so it takes 4.2 joules to heat 1 ml of water by 1 degree C. Now go get your calculator and work the rest out. Though personally I'd go with the 6m53s. |
#10 |
is the heat that comes from the stove the same ir heat that the 400w bulb is going to give off
| What, oil and water don't mix now?! | Wha' DIYa know? | Full Range | 9 | 26th May 2009 01:07 AM |
| Forgot to do this long long time ago | chris ma | Introductions | 2 | 30th October 2003 11:53 PM |
| water methods | PWatts | Multi-Way | 0 | 25th June 2003 11:46 AM |
| Long output lead or long output transistors leads? which one to pick? | chris ma | Everything Else | 3 | 6th June 2003 01:06 PM |
| Water cooled plate on ebay (possible water cooled amp application) | BrianGT | Parts | 1 | 27th May 2002 04:19 PM |
| Page generated in 0.09936 seconds (79.56% PHP - 20.44% MySQL) with 10 queries |
